Setting up custom menus to work on a network
I wonder if a lisp routine can be Tool Palette? Making toolbars are ok, but making the buttons are a pain.
I never have to setup custom menu’s to work off a Network so that everyone can use it before.
I know it is in the options, But is there a place on the web that I can find to help me to setup everyone’s work station to the custom menu on the network.
Trying to get everyone using the same blocks, layers, Toolbars & Tool bar Palletes.
Haha - while we're at it, do you want a LISP to make your coffee too? :P
1st step save your menus as seperate from Autocads then save once on network ok may not be right but simple go to each user and just use "menuload" to add menu.
Your menu should have all the lisp and blocks that you want to use programmed into it. Upgrade Autocad then you reload menu again simple. I have stayed away from toolbars for the reason of button images and just use a couple of pull menus (with sub menus) meets our needs more than fast enough.
Sure why not,
LOL.
I have been working 12 to 13 hours the past 3 months off and on and I need time to get custom menus, standards so every one using the same standards that where never set up. I have created some toolbars and add lisp routine that Lee Has created.
The CAD opperators can't thank you enough.
I’m trying to do what I can to get this CAD department Setup the right way a little at a time.
This Company is not willing to spend the money to get document control program or HVAC Programs so I look to my best resource. CADTUTOR and my CAD friend help.
I’m trying to get my hands on any and all lisp routines as I can.
That why I look for any help I can get here.
Any thing that makes this job easier makes my job bearable.
Do you when you can tell you are spending too much time at work?
Finding the imprint of the key board on your for head!
And pillow under your desk.
Your girl friend throwing to a welcome home party!
Ha Ha. :D :D :D
I'm glad i'm working, But I need a vacation soon.
  • 3 weeks later...
I do not know if I understood correctly but I think what you want is an enterprise CUI for all of the computers in your company. You keep the master in your computer. BTW, I also found that if put the LISP files in the LIS section of the CUI, you do not have to load them, they are loaded when the CUI is loaded.
