juicequad Posted March 21, 2009 Posted March 21, 2009 was wondering if anyone can help with a 2foot offset button. i want the 2foot offset then change the offset to the object layer i have ^C^C_offset 2' where do i go from there? Quote
Lee Mac Posted March 22, 2009 Posted March 22, 2009 In VL, it may look like this: (defun c:2off (/ ss) (vl-load-com) (if (setq ss (ssget (list (cons -4 "<NOT") (cons 0 "INSERT,VIEWPORT") (cons -4 "NOT>")))) (progn (foreach obj (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))) (mapcar 'vla-put-layer (vlax-safearray->list (vlax-variant-value (vla-offset obj 2))) (list (vla-get-layer obj))))) (princ "\n<!> Nothing Selected <!>")) (princ)) Quote
Cad64 Posted March 22, 2009 Posted March 22, 2009 The Offset command already has an option for moving the offset entity to the current layer. Just watch the command line. Example: Command: OFFSET Specify offset distance or [Through/Erase/Layer] : L Enter layer option for offset objects [Current/Source] : C Specify offset distance or [Through/Erase/Layer] : 2' You could automate this with a simple macro like this: ^C^C_offset;L;C;2';\ Quote
