kamo Posted July 9, 2024 Posted July 9, 2024 Hi All i have a block with dimensions in autocad ,i scaled it and i want to explode this block with its dimensions without changing in dimension value so if the dimension in block display 100 as value and the scale of the dimension of the block was 2 then i want from the exploded dimension (as text and lines) display 100 not dimension with 200 as value thanks in advance i wish you understand my bad language thanks again Quote
BIGAL Posted July 9, 2024 Posted July 9, 2024 Post a dwg, you will need to change the dim string to just that a string of vl -> Measurement rather than <> which is, "use default" distance between points. Then exolode. Quote
