thefisherman Posted July 16, 2024 Posted July 16, 2024 HI ALL, IF YOU DONOT MIND , I WOULD LIKE TO GET YOUR HELP TO SOLVE ISSUE WITH BLOCKS WITH ATTRIBUTES, I HAVE AN AUTOCAD FILE CONTAINS BLOCK WOTH ATTRIBUTES , AND THE ATTRIBUTES HAVE VALUE , AND IN THE SAME FILE I HAVE THE SAME BLOCK WITH SAME NAME AND SAME TAGS , BUT THE ATTRIBUTE VALUES ARE DIFF. , I WANT TO : - CHOOSE ONE OF THOSE BLOCKS -MAKE ALL BLOCKS IN THE DRAWING WITH THE SAME NAME OF THE BLOCK I SELECTED , TO HAVE THE SAME VALUES OF THE ATTRIBUTES OF THE BLOCK I HAVE SELECTED . Quote
thefisherman Posted July 16, 2024 Author Posted July 16, 2024 8 minutes ago, mhupp said: GATTE IT DID NOT WORK , I DONOT KNOW WHY , HERE IS THE EXAMPLE FILE OF WHAT I WANT TO DO , TAKE A LOOK AT IT . THE BLOCKS ON THE RIGHT HAND SIDE ARE WITH THE VALUES I WANT OTHER BLOCKS TO HAVE. trail for lisps.dwg Quote
mhupp Posted July 16, 2024 Posted July 16, 2024 its an express command so you would need to have that installed. Quote
thefisherman Posted July 16, 2024 Author Posted July 16, 2024 3 minutes ago, mhupp said: its an express command so you would need to have that installed. THE GATTE IS RUNNING IN AUTOCAD , BUT IT DIDNOT WORK TO MAKE JOB DONE BY IT . Quote
thefisherman Posted July 16, 2024 Author Posted July 16, 2024 13 minutes ago, thefisherman said: THE GATTE IS RUNNING IN AUTOCAD , BUT IT DIDNOT WORK TO MAKE JOB DONE BY IT . I THINK I FINDOUT WHY GATTE COUNTS 0 , AND DONOT WORK , BECAUSE THE BLOCK IS DYNAMIC . Quote
BIGAL Posted July 16, 2024 Posted July 16, 2024 This is for Title blocks in layouts, fill out one title block and all attributes are copied, not sure if you have say Model only. Update atts all layouts .lsp Quote
