Hi I am trying to insert a txt file with coordinates to tab with specific column width. The table created but is not correct and not fill with text. I attach a coordinate file for the code test.
(defun c:txt2tab (/ *error* del des hdl ins lin lst txt scl hgt)
  (setq scl (getvar "useri1"))
  (setq hgt (* 0.0005 scl))
  (defun *error* (msg)
    (if (= 'file (type des))
      (close des)
    (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
  (if (setq txt (getfiled "choose a file   P,X,Y (*.crd,*.txt,*.csv)" "" "crd;txt;csv" 16))
    (if (setq des (open txt "r"))
        (while (setq lin (read-line des))
          (setq lst (cons (mapcar '(lambda (a b) a) (LM:str->lst lin del)) lst))
        (setq des (close des))
        (if lst ;; Do we have a valid list?
          (if (setq ins (getpoint "\nSpecify point for table: "))
              (vl-cmdf "_LAYER" "_M" "TABLE" "_C" "7" "" "")
              (setq tlst (cons (list "A/A" (strcat "X" (if iunits (strcat "") " (?)")) (strcat "Y" (if iunits (strcat "") " (?)"))) tlst));
              (initget "1 2")
              (setq t_spc (cond ((getkword "\niNSERT TABLE : ? [1.Modelspace/2.Paperspace] <1>") "1")))
              (if (and (= tm 1) (= t_spc "2")) (setvar 'tilemode 0))
              (rh:AMT (vla-get-activedocument (vlax-get-acad-object)) "MY TABLE" tlst)
              (vl-cmdf "_SCALE" (entlast) "" ins hgt)
          (princ "\nNo valid data found in selected file.")
        (princ "\nUnable to open selected file for reading.")
  (mapcar 'setvar sv_lst sv_vals)
(defun rh:AMT (doc title lst / spc ipt t_obj rows cols row cell rdat)
  (setq spc (vlax-get-property doc (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))
        ipt (getpoint "\nSelect Table Insertion Point: ")
        t_obj (vla-addtable spc (vlax-3d-point ipt) (1+ (length lst)) (length (car lst)) 5.0 22.5))
  (vla-put-regeneratetablesuppressed t_obj :vlax-true)
  (mapcar '(lambda (x y) (vlax-put-property t_obj x y)) (list 'horzcellmargin 'vertcellmargin 'rowheight) (list 0.5 0.5 5.0))
  (vla-settextstyle t_obj (+ acDataRow acHeaderRow acTitleRow) "TOPOCAD")
  ;; Title row
  (vlax-invoke t_obj 'setrowheight 0 10.0)
  (vlax-invoke t_obj 'setcelltextheight 0 0 2.5)
  (vlax-invoke t_obj 'settext 0 0 title)
  (setq rows (- (vlax-get t_obj 'rows) 2)
        cols (1- (vlax-get t_obj 'columns))
        row 1
        cell 0)
  ;; Loop through data cells
  (while (< row rows)
    (setq rdat (nth (- row 1) lst))
    (while (<= cell cols)
      (vlax-invoke t_obj 'setcelltextheight row cell 2.5)
      (vlax-invoke t_obj 'settext row cell (nth cell rdat))
      (vlax-invoke t_obj 'setcellalignment row cell acMiddleCenter)
      (setq cell (1+ cell))
    (setq row (1+ row) cell 0)
  (vlax-invoke t_obj 'setcellalignment 1 0 acMiddleCenter)
  (vlax-invoke t_obj 'setcellalignment 2 0 acMiddleCenter)
  (repeat 2
    (vlax-invoke t_obj 'setrowheight row 6.0)
    (vlax-invoke t_obj 'mergecells row row 0 cols)
    (setq rdat (nth (1- row) lst))
    (vla-put-width t_obj 75)
    (vla-setcolumnwidth t_obj 0 15)
    (vla-setcolumnwidth t_obj 1 30)
    (vla-setcolumnwidth t_obj 2 30)
    (vlax-invoke t_obj 'setcelltextheight row 0 2.5)
    (vlax-invoke t_obj 'settext row 0 (car rdat))
    (setq row (1+ row))
  (vla-put-regeneratetablesuppressed t_obj :vlax-false)
Thanks
TEST.TXT
Edited by mhy3sx
I try to update the code but
Error: too few arguments
      (close des)
  ;; Define your delimiter (e.g., comma, semicolon)
  (setq del ",")
  (if (setq txt (getfiled "Choose a file (P,X,Y) (*.crd,*.txt,*.csv)" "" "crd;txt;csv" 16))
        (if lst ;; Do we have valid data?
              (initget "1 2")
              (setq t_spc (cond ((getkword "\nInsert table in Modelspace or Paperspace? [1.Modelspace/2.Paperspace] <1>") "1")))
          (princ "\nNo valid data found in the selected file.")
        (princ "\nUnable to open the selected file for reading.")
  ;; Title row
        row 1
        cell 0)
  (while (< row rows)
  (repeat 2
    (setq row (1+ row))
Edited by mhy3sx
A couple of comments
Dont need this IF as the fileypes should be readable
Only time not readable is if you dont have permission to read a file
see below
Need to add the LM:str->lst code into this code.
Dont need
rh:AMT is missing
It's very easy for other code to overwrite the USERIx values I use ldata.
(vlax-ldata-put "Mhy3sx" "Scl" scl) ; set default value if needed.
(setq scl (vlax-ldata-get "Mhy3sx" "Scl"))
Edited by BIGAL
Hi BIGAL. The code is not working and your tips don't help me. How to fix the code?
Quote
rh:AMT is missing
rh:AMT is in the code !!
Thanks
Edited by mhy3sx
I try this but Error: syntax error
(defun c:test (/ *error* del des hdl ins lin lst txt scl hgt)
      (close des)
  (setq del ",")
              (initget "1 2")
;                    Paper space                     ;
          (initget "1 2")
          (setq t_spc (cond ( (getkword "\nInsert table : ? [1.Modelspace/2.Paperspace] <1>")) ("1"))
          (rh:AMT c_doc (strcat "My Table " nme) tlst)
        (t (alert "No Polyline Selected"))
         );end_if
);end_defun
(defun rh:AMT ( doc title lst / spc ipt t_obj rows cols row cell rdat)
        t_obj (vla-addtable spc (vlax-3d-point ipt) (1+ (length lst)) (length (car lst)) 5.0 22.5) ; ίδιο πλάτος σε όλες τις στήλες 22.5
  );end_setq
  ; Title row
        row 1
        cell 0
  );end_setq
  ; loop through data cells
  (while (< row rows)
    );end_while
  );end_while
  (repeat 2
    ;(vlax-invoke t_obj 'setrowheight row 6.0)
    ;(vlax-invoke t_obj 'mergecells row row 0 cols)
    (setq row (1+ row))
  );end_repeat
);end_defun
In the error trap, *break needs a suffix asterisk.
Just before the "Paper space" comment, the setq tlst command is duplicated. Is that correct? Also, the indenting gets a little hard to follow.
Do you have trace capability? That is, can you pinpoint the location of the error? If not you can add trace statements as milestones, to see how far it got.
Or does it refuse to load? A good editor, even as simple as Notepad++, will highlight your syntax and help find these errors. Unless it's function usage, my lisp-fu is not strong enough to untangle everything that's going on here.
Hi Cyber Angel. I did the changes  but Error: syntax error
      (close des)
    (if (not (wcmatch (strcase msg t) "*break*,*cancel*,*exit*"))
  (setq del ",")
              (initget "1 2")
;                    Paper space                     ;
          (initget "1 2")
         );end_if
);end_defun
  );end_setq
  ; Title row
        row 1
        cell 0
  );end_setq
  (while (< row rows)
    );end_while
  );end_while
  (repeat 2
    (setq row (1+ row))
  );end_repeat
);end_defun
      (close des)
              (initget "1 2")
  ;; Title row
        row 1
        cell 0)
  (while (< row rows)
  (repeat 2
    (setq row (1+ row))
Thanks
TEST.TXT 698 B · 1 download
  (setq del ",")  ;; Set the delimiter for the text file
      (close des)
          (setq lst (cons (mapcar '(lambda (a) a) (LM:str->lst lin del)) lst))
              (setq tlst (cons (list "A/A" "X" "Y") (reverse lst)))  ;; Include headers and reverse list to maintain order
              (initget "1 2")
              (rh:AMT (vla-get-activedocument (vlax-get-acad-object)) "MY TABLE" tlst ins)
(defun LM:str->lst (str del / pos lst)
  (while (setq pos (vl-string-search del str))
    (setq lst (cons (substr str 1 pos) lst)
          str (substr str (+ pos 2))
  (reverse (cons str lst))
(defun rh:AMT (doc title lst ins / spc ipt t_obj rows cols row cell rdat)
        t_obj (vla-addtable spc (vlax-3d-point ins) (1+ (length lst)) (length (car lst)) 5.0 22.5))
  (vla-settextstyle t_obj (+ acDataRow acHeaderRow acTitleRow) "Standard")
  ;; Title row
  (setq rows (vlax-get t_obj 'rows)
        cols (vlax-get t_obj 'columns)
        row 1)
  (foreach rdat lst
    (setq cell 0)
    (foreach item rdat
      (vlax-invoke t_obj 'settext row cell item)
    (setq row (1+ row))
  ;; Set column widths
Edited by SLW210
Added Code Tags!!
Here you are... I've changed and cleaned your code...
HTH.
M.R.
(defun c:txt2tab ( / *error* LM:str->lst rh:AMT del des hdl ins lin lst txt scl hgt )
  (setq scl (if (not (zerop (getvar "useri1"))) (getvar "useri1") 1.0))
  (defun *error* ( msg )
    (if (= 8 (logand 8 (getvar (quote undoctl))))
      (if command-s
        (command-s "_.UNDO" "_E")
        (vl-cmdf "_.UNDO" "_E")
    (if (and des (= (quote file) (type des)))
      (close des)
    (if (and msg (not (wcmatch (strcase msg t) "*break*,*cancel*,*exit*")))
  ;; String to List  -  Lee Mac
  ;; Separates a string using a given delimiter
  ;; str - [str] String to process
  ;; del - [str] Delimiter by which to separate the string
  ;; Returns: [lst] List of strings
  (defun LM:str->lst ( str del / len lst pos )
    (setq len (1+ (strlen del)))
            str (substr str (+ pos len))
  (defun rh:AMT ( doc title lst ipt / spc t_obj rows cols row cell rdat )
    (if (not (tblsearch "LAYER" "TABLE"))
    );end_setq
    (mapcar (function (lambda ( x y ) (vlax-put-property t_obj x y))) (list 'horzcellmargin 'vertcellmargin 'rowheight) (list 0.5 0.5 5.0))
    ;(vla-settextstyle t_obj (+ acDataRow acHeaderRow acTitleRow) "TOPOCAD")
    ; Title row
    (setq rows (vlax-get t_obj 'rows) ;|(- (vlax-get t_obj 'rows) 2)|;
          row 1
          cell 0
    );end_setq
    (while (< row rows)
      );end_while
    );end_while
    (repeat 2
      (setq row (1+ row))
    );end_repeat
  );end_defun
  (vl-cmdf "_.UNDO" "_BE")
  (setq del ",")
          (setq lst (cons (LM:str->lst lin del) lst))
        (close des)
        (setq lst (reverse lst))
        (setq lst (cons (list "A/A" (strcat "X" (if iunits (strcat "") " (?)")) (strcat "Y" (if iunits (strcat "") " (?)")) (strcat "Z" (if iunits (strcat "") " (?)"))) lst))
              (vl-cmdf "_.LAYER" "_M" "TABLE" "_C" "7" "" "")
            (initget "1 2")
            (setq t_spc (cond ((getkword "\nInsert table in Modelspace or Paperspace? [1.Modelspace/2.Paperspace] <1> : ")) ("1")))
            (if (= t_spc "2") (setvar (quote tilemode) 0) (setvar (quote tilemode) 1))
            (if (setq ins (getpoint "\nPick or specify point for table : "))
                (rh:AMT (vla-get-activedocument (vlax-get-acad-object)) "MY TABLE" lst ins)
                (vl-cmdf "_.SCALE" (entlast) "" "_non" ins hgt)
                (vl-cmdf "_.ZOOM" "_E")
  (*error* nil)
);end_defun
Edited by marko_ribar
      (close des)
              (initget "1 2")
  ;; Title row
        row 1)
  (foreach rdat lst
    (setq cell 0)
    (foreach item rdat
    (setq row (1+ row))
Please use code tags for your code. (<> in the editor toolbar)
Hi marko_ribar.The table when insert in paper space don't have  text size 2.5 !!! Can you fix it ?
Thanks
I don't want the z column.I try to update the code but not working , and the column width is not 15,30,30 in layout
(defun c:test ( / *error* LM:str->lst rh:AMT del des hdl ins lin lst txt scl hgt )
      (if command-s
      (close des)
  (setq del ",")
        (close des)
            (initget "1 2")
  (*error* nil)
);end_defun
    );end_setq
    ; Title row
          row 1
          cell 0
    );end_setq
    (while (< row rows)
      );end_while
    );end_while
    (repeat 2
      (setq row (1+ row))
    );end_repeat
  );end_defun
Edited by mhy3sx
See if this version suits more...
(defun c:txt2tab ( / *error* LM:str->lst rh:AMT del des hdl ins lin lst txt scl hgt hgtm hgtp )
  (setq scl (getvar (quote useri1)))
  (if (/= scl 0)
    (setq hgtm (* 0.0025 scl))
    (setq hgtm 0.0025)
  (setq hgtp 1.0)
      (if command-s
      (close des)
    );end_setq
    ; Title row
          row 1
          cell 0
    );end_setq
    (while (< row rows)
      );end_while
    );end_while
    (repeat 2
      (setq row (1+ row))
    );end_repeat
  );end_defun
  (setq del ",")
          (setq lst (cons (reverse (cdr (reverse (LM:str->lst lin del)))) lst))
        (close des)
        (setq lst (cons (list "A/A" (strcat "X" (if iunits (strcat "") "")) (strcat "Y" (if iunits (strcat "") ""))) lst))
            (initget "1 2")
            (if (= t_spc "2")
                (setq hgt hgtp)
                (setq hgt hgtm)
  (*error* nil)
);end_defun
Hi marko_ribar. The problem not fix. All the time the scale is set in the drawing. So I want when I am in the model space the text height be (*0.0025 scl ) and when I am in paper space text height be 2.5
  (setq hgt (* 0.0025 scl))
      (if command-s
      (close des)
    );end_setq
    ; Title row
          row 1
          cell 0
    );end_setq
    (while (< row rows)
      );end_while
    );end_while
    (repeat 2
      (setq row (1+ row))
    );end_repeat
  );end_defun
  (setq del ",")
        (close des)
            (initget "1 2")
  (*error* nil)
);end_defun
Thanks
@mhy3sx
I've updated my lastly posted code... See if that's what you're looking for...
Regards, M.R.
The only thing I change is
  (if (/= scl 0)
    (setq hgtm (* 0.001 scl))
    (setq hgtm 0.001)
because for example for scale 1:200 0.0025* 200 =0.5 but in model space insert the table with text  size 1.25 ,  2.5 times bigger.  A quick hack is to change to (* 0.001  scl)
Thanks marko_ribar.
Hi Marko
Made a suggestion about using Ldata rather than UserI1 as this can be overwritten by other code. See above.
Just a observation and I may be wrong often are.
In setting the text height for the table you get the current value spc so maybe move that line above the get scl and set the correct row height as you know which scale factor to use. In the title row and data row, height is set to 2.5 would this not change based on Model or paper ?
Just a suggestion something I did was make a Table style say "Sc200M" for scale 1:200 in Model likewise "Sc200P", if extra tables are required the Table style already exits. Lee-mac Steal.lsp has Table style as an option. Its like 3 lines of code to use. For us we generally only used 2 or 3 scales so could have a dwg with all those table styles in it, or maybe add to a DWT.
