skipsophrenic Posted March 24, 2009 Share Posted March 24, 2009 Problem: When you look at a drawing in preview it looks great, ready to go out to the client and you do one last check print. . . .BOLD text??????? and nothing you think of stops it? Solution: 1. Use QSELECT, select your entire drawing, and select ALL instances of MTEXT. 2. Go into properties box, change Z elevation to 10 (number of own choosing. 3. change Z Elevation back to 0. 4. repeat in model/layout as required. this should stop these occurences Quote Link to comment Share on other sites More sharing options...
