420325 Posted November 14, 2007 Posted November 14, 2007 I am trying to find or build a LISP that will insert a block @ +20' Z coord. locate it with the insertion point of the block, and then rotate it from the center of the block. If that dosn;t make scence what I am trying to do is insert an elevation marker on a pipe then rotate it to allign with it. THANKS I found this but I am not good at editing LISP Here's an AutoDesk lisp for copy rotate. ;;; Mcr.Lsp ;;; Copyright (C) 1990 by Autodesk Australia Pty. Ltd. ;;; ;;; Permission to use, copy, modify, and distribute this software and its ;;; documentation for any purpose and without fee is hereby granted. ;;; ;;; THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED WARRANTY. ;;; ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR PURPOSE AND OF ;;; MERCHANTABILITY ARE HEREBY DISCLAIMED. ;;; ;;;------------------------------------------------------------------------- ;;; DESCRIPTION: ;;; ;;; Mcr.Lsp provides two new commands, MoveRot and CopyRot. ;;; MoveRot, MOVEs and ROTATEs selected entities whilst ;;; CopyRot, COPYies and ROTATEs selected entities. ;;; ;;; Written by Sam Crupi, Autodesk Australia Pty. Ltd. ;;; October 1987 ;;; Modified by Jeff De Silva & Sam Crupi, Autodesk Australia Pty. Ltd. ;;; November 1990 ;;; ;;; Version 1.0 ;;; 4 December 1990 ;;; ;;;------------------------------------------------------------------------- ;;; ;;; Error function ;;; (defun mcr_err (s) ; If an error (such as CTRL-C) occurs ; while this command is active... (if (/= s "Function cancelled") (if (= s "quit / exit abort") (princ) (princ (strcat "\nError: " s)) ) ) (if mcr_oer ; If an old error routine exists (setq *error* mcr_oer) ; then, reset it ) (if mcr_oce ; Reset command echoing on error (setvar "cmdecho" mcr_oce) ) (princ) ) ;;; ;;; Command MoveRot ;;; (defun c:MoveRot (/ sset mcr_oce mcr_oer) (setq mcr_oce (getvar "cmdecho")) ; save cmdecho setting (setvar "cmdecho" 0) ; turn cmdecho off (if *error* ; Set our new error handler (setq mcr_oer *error* *error* mcr_err) (setq *error* mcr_err) ) (princ (strcat "\nMoveRot, Version " mcr_ver ", (C) 1990 by Autodesk Australia Pty. Ltd. " ) ) (if (setq sset (ssget)) ; get selection set (progn (setvar "cmdecho" 1) ; turn cmdecho on to allow MOVE ; prompts to appear (command "MOVE" sset "" pause pause) ; MOVE them ;; now ROTATE the selection set using the LASTPOINT as Base point (command "ROTATE" sset "" (getvar "LASTPOINT") pause) ) ) (setvar "cmdecho" mcr_oce) ; reset cmdecho to old setting (if mcr_oer ; If an old error routine exists (setq *error* mcr_oer) ; then set it back ) (princ) ) ;;; ;;; Command CopyRot ;;; (defun c:CopyRot (/ mcr_oce mcr_oer sset) (setq mcr_oce (getvar "cmdecho")) ; save cmdecho setting (setvar "cmdecho" 0) ; turn cmdecho off (if *error* ; Set our new error handler (setq mcr_oer *error* *error* mcr_err) (setq *error* mcr_err) ) (princ (strcat "\nCopyRot, Version " mcr_ver ", (C) 1990 by Autodesk Australia Pty. Ltd. " ) ) (if (setq sset (ssget)) ; get selection set (progn (command "COPY" sset "" "0,0" "0,0") ; COPY selection set over itself (setvar "cmdecho" 1) ; turn cmdecho on to allow MOVE ; prompts to appear (command "MOVE" "p" "" pause pause) (redraw) ; Redraw screen ;; now ROTATE the selection set using the LASTPOINT as Base point (command "ROTATE" "p" "" (getvar "LASTPOINT") pause) ) ) (setvar "cmdecho" mcr_oce) ; reset cmdecho to old setting (if mcr_oer ; If an old error routine exists (setq *error* mcr_oer) ; then set it back ) (princ) ) ;;; ;;; Define the c: functions. ;;; (defun c:MR () (c:MoveRot) ) (defun c:CR () (c:CopyRot) ) (setq mcr_ver "1.0") ; set version number string ;;(princ (strcat "\nC:MCR (v" mcr_ver ") loaded.")) ;;(princ "\nMR or MoveRot to Move and Rotate, CR or CopyRot to Copy and Rotate.") (princ) Quote
2001jonathon Posted December 11, 2007 Posted December 11, 2007 I am trying to find or build a LISP that will insert a block @ +20' Z coord. locate it with the insertion point of the block, and then rotate it from the center of the block. If that dosn;t make scence what I am trying to do is insert an elevation marker on a pipe then rotate it to allign with it. THANKS I found this but I am not good at editing LISP Why dont you try sothing like this. (defun c:spinblk (/ doc ss ll ur midpt) (vl-load-com) (if (and (ssget '((0 . "INSERT"))) (setq doc (vla-get-activedocument (vlax-get-acad-object) ) ) (setq ss (vla-get-activeselectionset doc)) ) (progn (vlax-for ent ss (vla-getboundingbox ent 'll 'ur) (setq ll (vlax-safearray->list ll) ur (vlax-safearray->list ur) midpt (mapcar '/ (mapcar '+ ll ur ) '(2.0 2.0 2.0) ) ) (vlax-invoke ent 'rotate midpt pi) ) ) ) (princ) ) or you can make a lisp that allows you to insert a block and then using macros tell the block to do a task. Quote
laison Posted March 11, 2009 Posted March 11, 2009 I have a lisp that move an object 2D and 3D. I want to add on to it or file another file where it will move and rotate alone the same axis. Let's say I have a pipe with tee pointing up and I need to connect to it. That line might be say in the horizontal. The fittings I am adding are a unknown distance and unknown angle. I am looking for a lisp file that will move and rotate the elbow are tee and keep it inline just by selecting the tee that need to connect to. This has to a 3D lisp. This is the file that I found and would like to modify (if possible): MPF.lsp Quote
