I've been using the lisp from THIS thread since i got it.
Up untill now have not had any problems, howevey when
i used it today, looking at everythin from the side, it has l
eft entities on 3 distinct elevations,
Any clue's on why this is happening now?
F.Y.I. this is a BIG drawing
I may be way off the mark here, but have you tried the LISP with all your OSNAPs off?
from quickly glancing at the LISP on the hyperlinked threads, I notice that it doesn't turn OSNAPs off before moving the entities... :huh:
Also, check that the entities are not on locked layers, as this will also cause a problem.
This should cope with R14, and also with objects on locked layers:
(defun c:flat  (/ ss ssObj i j)
 (vl-load-com)
 (if (setq ss (ssget "X"
             (list (if    (getvar "CTAB")
                 (cons 410 (getvar "CTAB"))
                 (cons 67 (- 1 (getvar "TILEMODE")))))))
     (setq ssObj (mapcar 'vlax-ename->vla-object
             (mapcar 'cadr (ssnamex ss))) i 0 j 0)
     (foreach Obj  ssObj
   (foreach n  '(1e99 -1e99)
     (if (vl-catch-all-error-p
       (vl-catch-all-apply
         '(lambda (x)
            (vla-move x (vlax-3d-point (list 0 0 0))
                  (vlax-3d-point (list 0 0 n))))
         (list Obj)))
       (setq i (1+ i)) (setq j (1+ j)))))
     (princ (strcat "\n" (rtos (/ j 2.0)) " Objects Flattened"
            (if (zerop i) "." (strcat ", " (rtos (/ i 2.0))
                          " were on a Locked Layer!")))))
   (princ "\n<!> No Objects Found <!>"))
 (princ))
Thanks 4 the tips - i'll try them tomorraz when I get to work
Will do - won't be untill afternoon tho - am at limb centre in mornin gettin me new leg (Hopefully)
Its not everyday you get to say that now is it... :P
Only once a year! LOL :lol:
Alternatively, this will unlock all layers before performing the flatten:
(defun c:flat  (/ laylst ss ssObj j)
 (vl-load-com)
 (vlax-for lay
        (vla-get-layers
          (vla-get-ActiveDocument
            (vlax-get-acad-object)))
   (setq laylst (cons lay laylst)))
 (mapcar '(lambda (l) (vla-put-lock l :vlax-false)) laylst)
             (mapcar 'cadr (ssnamex ss))) j 0)
     (foreach Obj  ssObj
       (vl-catch-all-apply
         '(lambda (x)
         (list Obj)))
       nil (setq j (1+ j)))))
     (princ (strcat "\n" (rtos (/ j 2.0)) " Objects Flattened.")))
 (princ))
Cool - I'm deffinately gonna test these tommorraz - u don't realise how much these'll help m8.
Al I can say is thanks
if Lees suggestion doesnt work try -exporttoautocad press enter for your first selection then give a new name for the second. It will create a new dwg file with the same info but flattened. Every once in a while we get drawings that just dont want to flatten, or flat or zero(change all z values to 0) but this seems to work even when nothing else will. hope it helps
