Q: Open the same file not "read only"
Hi
In Autocad 2008; is posible to open the same file in two or more Autocad in a network not read only in order to modify the same file two or more users. Thanks
Thanks...and in other Release?
You can do that in Map. It allows two different users to operate in different areas and/or objects of the same drawing at the same time.
Thanks to everyone for try to help me; basically I work in an Fire Alarm CO; example
In a fire alarm proyect you usually have several floors and one riser for the proyect them I need that two or more friends can work in diferents floor but modify the same riser in order to finish faster the proyect and not wait for others to finish his update in the riser for do the same.
