Sir,
Pl.tell me that How can we fixed two points coordinates (simultanious) in an
image of sajra map.
Thanks
K.K.Yadav
I have moved your question to it's own thread, please start a new thread for each new question you have.
Second, could you tell us why you need this? What is the goal? I mean, you can easily find the coordinates of one point with LIST or ID - why do you need to get two simultaneously?
Guessing..
If you want to scale and rotate an image to fit 2 known coordinates, the ALIGN command would be helpful-much quicker than trial and error.
Please ignore this if this was not the question :)
I suppose this has a simultaneous output... :P
(defun c:id2 (/ i mStr pt ptstr)
 (setq i 1 mStr "")
 (while (setq pt (getpoint "\nSelect Point or <exit>: "))
   (setq ptstr (strcat "Pt " (itoa i) (chr 32)
   (rtos (car pt) 2 2) (chr 44) (rtos (cadr pt) 2 2)
      (chr 44) (rtos (caddr pt) 2 2)))
   (setq mStr (strcat mStr ptstr "\n") i (1+ i)))
 (alert mStr)
 (princ))
sir,
I would like to inform to you,that it's required for highway project for land Equaisition purpose,
1. scan sajra & How to fix two points on sajra as per site Chanages?Pl. tell me.
this is my goal for Land Acquiasition purpose.
Thanks,
K.K.Yadav
how to customise the command in a autocad 2007.
thanks.
kkyadav
thanks.
kkyadav
Could you clarify what you are requesting please?
It is very clear that when i am customise line command ,we are found only icon.
