repelectric Posted March 31, 2009 Share Posted March 31, 2009 yesterday I was working on the project and today I open the file and the scale is off my layout is set currently on 36"x24" but when I draw a line, the dimension of the line is 50 feet which should be somewhere around up to 3'. All my units and scale set normally as usual but when I draw on the layout is in big dimensions. Please Help Thanks, Also, when I am trying to change something in units command and click apply it wont apply changes Quote Link to comment Share on other sites More sharing options...
wannabe Posted March 31, 2009 Share Posted March 31, 2009 yesterday I was working on the project and today I open the file and the scale is off my layout is set currently on 36"x24" but when I draw a line, the dimension of the line is 50 feet which should be somewhere around up to 3'. All my units and scale set normally as usual but when I draw on the layout is in big dimensions. Please Help Thanks, Also, when I am trying to change something in units command and click apply it wont apply changes I'm used to blocked settings that are controlled at the project level or admin level when using projectwise for mainly Microstation drawings. Anything that sounds relevant? Quote Link to comment Share on other sites More sharing options...
repelectric Posted March 31, 2009 Author Share Posted March 31, 2009 I am the one who created the file and the only one who uses. even I open a new drawing and go to layout the numbers (dimensions) are very high which should be in around up to 3' not 50' to 100'. I installed AutoCAD 2010 MEP it that could be a problem. samething i cannot change units in AuotCAD 2010 MEP it wont apply. Quote Link to comment Share on other sites More sharing options...
Came Posted March 31, 2009 Share Posted March 31, 2009 use repair allways when installing new autocad product worth a try :wink: download fixes from sites, if there's any Quote Link to comment Share on other sites More sharing options...
