jbwilliamz Posted April 2, 2009 Share Posted April 2, 2009 Hey, There seems to be a problem when I'm trying to plot one of my drawings! I'm converting the CAD drawing into PDF (easier to plot for a friend) through CutePDF, then when I preview the drawing as a PDF, there seems to be a long black strip accorss the bottom of my drawing..!? I've purged/audited the drawing and eveything seems fine. Any ideas what this could be? I have never had the problem before either. Jb Quote Link to comment Share on other sites More sharing options...
Tiger Posted April 2, 2009 Share Posted April 2, 2009 Is it a 3D-drawing? If it is, I'm kinda glad because it's happening to me all the time with every 3D-drawings. I've solved it with using the Dwg to PDf printer instead. Quote Link to comment Share on other sites More sharing options...
jbwilliamz Posted April 2, 2009 Author Share Posted April 2, 2009 Na, sorry matey! It's not. ANother thing, when I print preview it in CAD, everything seems fine!! Just when it's converted to PDF that's all. What the hell!? Quote Link to comment Share on other sites More sharing options...
PS_Port Posted April 2, 2009 Share Posted April 2, 2009 Sounds like text masks, cutepdf does that to mine sometimes jb, you probably understand text masks wiping every thing out underneath the text, but some pdf printers see that wipeout or mask as a rectangle filled in, to be plotted. try selecting some of the text to see if there is a mask in the properties dialog box and delete the mask if there is one. Quote Link to comment Share on other sites More sharing options...
jbwilliamz Posted April 2, 2009 Author Share Posted April 2, 2009 Problem (kinda) solved. Copied the majority of the drawing I did, apart from the problem area (which was a couple of dimensions) and basically re-drew what was missing. Seems to have done the trick. Cheers! Quote Link to comment Share on other sites More sharing options...
ssd Posted April 8, 2009 Share Posted April 8, 2009 Use PDF995 freeware for conversion to avoid the problem. Quote Link to comment Share on other sites More sharing options...
