jack0615 Posted October 15, 2010 Posted October 15, 2010 I use 2010 ver. acad.dwt to draw 2 circles with radius 50 and 2.Then I make 2 dimradius and change the dimension scale up to 10. Here is my problem. I need 2 Viewports in a layout with different scale 1:1 and 4:1 and wish both dimensions be the same size.. So I create a new dimension style with annotation and change the small one but when I drop down the viewport scale and select 4:1 in the status bar but the arrow and text is too small to read. What am I doing wrong? Any suggestion will be appreciate. I made a big mistake. I use standard & Iso-25 dimension style which use different text height with 0.18 & 2.5, so it is impossible to show the same text height in 2 viewports. Quote
ReMark Posted October 15, 2010 Posted October 15, 2010 Aren't those the default heights? They can be changed right? Quote
jack0615 Posted October 16, 2010 Posted October 16, 2010 Yes, I can change the default text height in dimension style. Thanks again. Quote
