SaigoLives Posted April 2, 2009 Posted April 2, 2009 I've been rendering for about 7-8 years (and still prefer to work in AutoCAD 2000 in this instance), but I still haven't figured out to either create a shaped light source, or to declare a solid as a light source (if either of these is possible). I'm getting into rendering office buildings in conjunction with specialty warehousing we design, and a ceiling grid (and the corresponding light fixtures) would make a great touch. Any help on this one would be appreciated. Quote
AONE_LED Posted 1 hour ago Posted 1 hour ago In AutoCAD 2000 you cannot declare a solid as a light source, and photometric weblights did not exist yet. Model each fluorescent as a simple 26 mm (T8) or 16 mm (T5) cylinder, then place a row of low-intensity point lights along the tube centreline at about 200–300 mm centres so the light is even. Give the tube a pale, slightly self-illuminated material so the lamp reads as glowing in the render; keep the housing as ordinary geometry so it can cast a soft shadow. For a ceiling grid, copy this fixture as a block to each troffer location and aim the lights downward. If you later move to AutoCAD 2007 or newer, set LIGHTINGUNITS to 2 (SI) and use one WEBLIGHT per fixture with a manufacturer IES file instead. Quote
