leviathin79 Posted April 3, 2009 Posted April 3, 2009 ultra newbie here, so i started up autocad for the first time today, i have been playing with it for a couple of hrs now and i cant figure out how to find out what the degrees are between two lines that i have drawn. example draw a 2" line from start point 2,2 @ 27degrees - then draw another 2" line from start point 2,2 @ 53 degrees now what i would like is for autocad to tell me what the degrees are between those two line i.e. 26 degrees yes i can go and do the math my self but i have a large diagram that i imported and i was wondering if there was a feature that does this for you. if anyone can help that would be awesome, or if you could point me in the right direction for a tutorial that will explain how to do this that would be cool, i have been searching google high and low but i am not sure if i am asking the question right. thanks for any help Ken Quote
lpseifert Posted April 3, 2009 Posted April 3, 2009 OOTB Acad doesn't have a direct way to do an inquiry to measure angles between lines (unless they added it since 2008), but you can use the Dimangular command to find the angle; just escape before placing the dimension. Here's another option http://cadtips.cadalyst.com/linear-objects/angle-between-two-lines Quote
CADgirl Posted April 3, 2009 Posted April 3, 2009 Use the angular dimension. It's under the dimension pull down menu. Quote
Tankman Posted April 3, 2009 Posted April 3, 2009 Dimension menu, angular. I keep the dimension tool bar, always shown, to the right of my screen (vertically). Quote
leviathin79 Posted April 3, 2009 Author Posted April 3, 2009 thanks guys, i dont know how the measurement angle button eluded me before but i am golden now, thanks again Quote
alanjt Posted April 3, 2009 Posted April 3, 2009 Use the angular dimension. It's under the dimension pull down menu. or type "DAN" Quote
