Dale Bechtel
text in paper space appears very thick and solid
Dale Bechtel
I have some drawings that the text appears very thick and solid in paper space.
Plots fine though.
i am still using a SHX font (architxt)
it shows fine in model space
only some drawings have this problem
i have checked txtfill and such commands
has anyone els ever had this issues?
again, it does not effect plotting, so its only annoying, not a real problem
thanks, Dale
Share this post
Link to post
riga
Plots fine though.
thanks, Dale
This problem is common when using TTF fonts: some text in some file appear bold but when printed they look good (and I've seen this problem discussed in many forums with no clear explenation of the reasons why this happend).
This is the first time I hear that about SHX fonts.
BTW, on those fonts fillmode should not have effects because it's the lineweight (defined in the drawing or with the plot style) that should determine the width of the lines that forms the letters
Share this post
Link to post
SLW210
Could you post your drawing or at least the portion with the text?
Share this post
Link to post
smorales02
is it just text that appears thick?
Share this post
Link to post
mahahaavaaha
I repeat SLW210's intention; please post an example!
/Petri
Share this post
Link to post
GE13579
Just a workaround, but turn off the LWT button at the bottom of the page.
Share this post
Link to post
Dale Bechtel
I just uploaded a sample dwg with the text problem,
but there is no way to make it 250 kb, which I thought i saw was the limit, so i am not sure it is uploaded. It called sampletextdwg.zip
Its a zipped file
thanks, dale
Share this post
Link to post
Dale Bechtel
I am using Acad 2002 still, i do not see LWT button, but will try to run it in command line
Share this post
Link to post
Dale Bechtel
Yes, it is just the text that appears thick.
Share this post
Link to post
riga
Nothing wrong in your drawing as far as I can see.
It's LWT on that give you the bold effect (as someone stated before).
Just turn it off > LWDISPLAY > OFF (or 0)
Share this post
Link to post
Dale Bechtel
Thanks very much, something so simple...you would think i should have figured that out..
thanks again
Dale
Share this post
Link to post
Dale Bechtel
thanks, It was the lwdisplay command
Share this post
Link to post
Dale Bechtel
thanks again
Dale
Share this post
Link to post
SLW210
Yea, fixed on my machine by turning of the LWT button at the bottom.
Share this post
Link to post
GE13579
You're welcome :thumbsup:
Share this post
Link to post
Greg001
I have had the same problem. The effected text has a Z value when listed even though it is in paper space. If I move the text to x,x,0'-0" it appears as it should.
I don't know how it gets moved in the Z direction in paper space but it does. It has started showing up on my plots too which won't be helped by the LWT setting!
I hope this helps.
Greg
Share this post
Link to post
nukecad
I hope this helps.
Probably a bit late, 10 years to the day late.
Share this post
Link to post
Greg001
You are correct. However folks are always looking for answers. And, there's no such thing as stale question. Stale threads perhaps... besides, I'm new to this site/forum and admittedly didn't notice the date.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
