Dale Bechtel Posted December 5, 2007 Share Posted December 5, 2007 I have some drawings that the text appears very thick and solid in paper space. Plots fine though. i am still using a SHX font (architxt) it shows fine in model space only some drawings have this problem i have checked txtfill and such commands has anyone els ever had this issues? again, it does not effect plotting, so its only annoying, not a real problem thanks, Dale Quote Link to comment Share on other sites More sharing options...
riga Posted December 5, 2007 Share Posted December 5, 2007 I have some drawings that the text appears very thick and solid in paper space. Plots fine though. i am still using a SHX font (architxt) it shows fine in model space only some drawings have this problem i have checked txtfill and such commands has anyone els ever had this issues? again, it does not effect plotting, so its only annoying, not a real problem thanks, Dale This problem is common when using TTF fonts: some text in some file appear bold but when printed they look good (and I've seen this problem discussed in many forums with no clear explenation of the reasons why this happend). This is the first time I hear that about SHX fonts. BTW, on those fonts fillmode should not have effects because it's the lineweight (defined in the drawing or with the plot style) that should determine the width of the lines that forms the letters Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 5, 2007 Share Posted December 5, 2007 Could you post your drawing or at least the portion with the text? Quote Link to comment Share on other sites More sharing options...
smorales02 Posted December 5, 2007 Share Posted December 5, 2007 is it just text that appears thick? Quote Link to comment Share on other sites More sharing options...
mahahaavaaha Posted December 6, 2007 Share Posted December 6, 2007 I repeat SLW210's intention; please post an example! /Petri Quote Link to comment Share on other sites More sharing options...
GE13579 Posted December 6, 2007 Share Posted December 6, 2007 Just a workaround, but turn off the LWT button at the bottom of the page. Quote Link to comment Share on other sites More sharing options...
Dale Bechtel Posted December 6, 2007 Author Share Posted December 6, 2007 I just uploaded a sample dwg with the text problem, but there is no way to make it 250 kb, which I thought i saw was the limit, so i am not sure it is uploaded. It called sampletextdwg.zip Its a zipped file thanks, dale Quote Link to comment Share on other sites More sharing options...
Dale Bechtel Posted December 6, 2007 Author Share Posted December 6, 2007 I am using Acad 2002 still, i do not see LWT button, but will try to run it in command line Quote Link to comment Share on other sites More sharing options...
Dale Bechtel Posted December 6, 2007 Author Share Posted December 6, 2007 Yes, it is just the text that appears thick. Quote Link to comment Share on other sites More sharing options...
riga Posted December 6, 2007 Share Posted December 6, 2007 If file is too large then upload here: http://www.megaupload.com/en/ and then post here on the forum the link to download the file Quote Link to comment Share on other sites More sharing options...
Dale Bechtel Posted December 6, 2007 Author Share Posted December 6, 2007 If file is too large then upload here:http://www.megaupload.com/en/ and then post here on the forum the link to download the file here is the link http://www.megaupload.com/?d=CW3XHI98 thanks, dale Quote Link to comment Share on other sites More sharing options...
riga Posted December 6, 2007 Share Posted December 6, 2007 Nothing wrong in your drawing as far as I can see. It's LWT on that give you the bold effect (as someone stated before). Just turn it off > LWDISPLAY > OFF (or 0) 1 Quote Link to comment Share on other sites More sharing options...
Dale Bechtel Posted December 6, 2007 Author Share Posted December 6, 2007 Nothing wrong in your drawing as far as I can see.It's LWT on that give you the bold effect (as someone stated before). Just turn it off > LWDISPLAY > OFF (or 0) Thanks very much, something so simple...you would think i should have figured that out.. thanks again Dale Quote Link to comment Share on other sites More sharing options...
Dale Bechtel Posted December 6, 2007 Author Share Posted December 6, 2007 thanks, It was the lwdisplay command Quote Link to comment Share on other sites More sharing options...
Dale Bechtel Posted December 6, 2007 Author Share Posted December 6, 2007 Just a workaround, but turn off the LWT button at the bottom of the page. Thanks very much, something so simple...you would think i should have figured that out.. thanks again Dale Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 6, 2007 Share Posted December 6, 2007 Yea, fixed on my machine by turning of the LWT button at the bottom. Quote Link to comment Share on other sites More sharing options...
GE13579 Posted December 6, 2007 Share Posted December 6, 2007 You're welcome Quote Link to comment Share on other sites More sharing options...
Greg001 Posted December 6, 2017 Share Posted December 6, 2017 I have had the same problem. The effected text has a Z value when listed even though it is in paper space. If I move the text to x,x,0'-0" it appears as it should. I don't know how it gets moved in the Z direction in paper space but it does. It has started showing up on my plots too which won't be helped by the LWT setting! I hope this helps. Greg Quote Link to comment Share on other sites More sharing options...
nukecad Posted December 6, 2017 Share Posted December 6, 2017 I hope this helps. Probably a bit late, 10 years to the day late. Quote Link to comment Share on other sites More sharing options...
Greg001 Posted December 6, 2017 Share Posted December 6, 2017 You are correct. However folks are always looking for answers. And, there's no such thing as stale question. Stale threads perhaps... besides, I'm new to this site/forum and admittedly didn't notice the date. 1 Quote Link to comment Share on other sites More sharing options...
