chrisdarmanin Posted April 7, 2009 Share Posted April 7, 2009 Command: DIM Dim: Type EXIT to return to COMMAND prompt. Dim: EXIT Command: i once typed DIM in the command line and all i got was as shown above, but i don't know how to use it... can someone explain please? thanks Quote Link to comment Share on other sites More sharing options...
NBC Posted April 7, 2009 Share Posted April 7, 2009 at the prompt DIM: you can enter things like HOR (for a horizontal dimension) VER (for a vertical dimension), etc. Alternatively, you can press F1 to read the help file. Quote Link to comment Share on other sites More sharing options...
dbroada Posted April 7, 2009 Share Posted April 7, 2009 Alternatively, you can press F1 to read the help file.Unless you've programmed it to behave like the key Quote Link to comment Share on other sites More sharing options...
GE13579 Posted April 7, 2009 Share Posted April 7, 2009 Unless you've programmed it to behave like the key ...Then CTRL+F1 should work (or is it shift???) Quote Link to comment Share on other sites More sharing options...
lpseifert Posted April 7, 2009 Share Posted April 7, 2009 I think Dim was kept for legacy reasons, back in the old days of DOS Acad, you had to invoke the dimensioning commands by entering Dim first (dimensioning was sort of like a separate module). Quote Link to comment Share on other sites More sharing options...
