Recovering multiple files
I have searched the forums with no results. I am using ACA2009. Is there a way to recover multiple files at once instead of having to do each file one at a time? I tried writing a script routine with no success. Thanks in advance.:?
Your script will have to be called from a .bat file so each drawing can be opened and the script run. If no one posts by the time I look up again how to do that I will post back.
Sounds like a good application for AutoDesk's Scriptpro.
I did not think about .bat files. I found Hurricane and it seems to do the trick.:)
Thanks all.
