Checking saved times for each object
I'm currently developing a lab course for AutoCad. In order to prevent other students to copying one another, I would like to know if there is a way in which I can check the completed time of each object or assignment they have done.
Thanks.
Bill,
Have a look at my CadTempo program, It's not a free solution but the 30 day trial might give you every thing you need. That is if your students are conducting the projects on school computers the program is loaded on. You should be able to see the time spent students even if copied.
If you right click the dwg file and look in Properties under the statistics tab, there should be listed "Last saved by" and "Total editing time" information.
