Tiger Posted April 9, 2009 Author Posted April 9, 2009 attached - tried to change it to Overlay and didn't seem to make a difference. Quote
NBC Posted April 9, 2009 Posted April 9, 2009 This may be a rather daft question; but did you save M with those layer states contained within them; and then whilst in Q, did you reload xref M ? Also just as a test, make a copy of drawing Q, rename to something like 01. In this 'new' drawing 01, detach xref M and save the file, and then close it. Reopen drawing 01; and attach xref M. Now do the layerstates contained within M migrate across ? Quote
Tiger Posted April 9, 2009 Author Posted April 9, 2009 Hey, there's a reason the first question from any tech-support is "have you plugged it in?" - I am however fairly sure that I did save it. And I just closed everything and re-openend M and I was able to restore the new layer state so it is saved in M. And as of your suggestion, I made a copy of Q, detached M, saved, closed, openend and still no layer States... what is really weird is that the ones from A,B and C are migrated right across to Q..but not the ones created in M... Quote
NBC Posted April 9, 2009 Posted April 9, 2009 very strange indeed i'm at a loss as to how to help further Quote
chulse Posted April 9, 2009 Posted April 9, 2009 I have run into this scenario also. I've had someone help me with a lisp solution, but I have not tested it yet. Let me test what I have and I will let you know... Have a look here: http://www.theswamp.org/index.php?topic=27679.0 Quote
Tiger Posted April 9, 2009 Author Posted April 9, 2009 Thanks for all NBC, I don't get why it doesn't work either. Chulse - that sounds promising, if nothing else I'll get to trying this next week - right now I just gotta get it done, even if I have to do it the old fashioned way. Quote
BrownKeithA Posted April 9, 2009 Posted April 9, 2009 I was wondering which autocad product you are using. If you happen to be using Autocad MEP, there is a setting that will do this for you automatically. In the project settings you can set sheet files to automatically sync with view files. Construct, View, and Sheet files follow the same xrefing structure that you are mentioning. You create a Construct and xref it into a view file where you would annotate it. Then you would xref the view file into several different sheets. The view drawings is divided into several different sheets all of which need to mimic the layer settings of the view file. It will automatically sync your layer settings. I am not sure if you are using MEP, but if you are, this will solve your problem IF you are using the project management system. Quote
Tiger Posted June 11, 2009 Author Posted June 11, 2009 Chulse - did you ever get the lisp from TheSwamp to work? I'm back to this problem now and would really like to get this to work... I however know nothing about Lisps and I get a long error from the lisp Quote
