marlon Posted April 9, 2009 Share Posted April 9, 2009 There are two 3d objects, if i click on one (selecting it), the other automatically gets selected too. If I select either one and assigns a different layer name to it, for example MyLayer, the other one becomes a MyLayer also! This is a problem because if I wish to delete or move either one of them, the other one would also be deleted or moved. Please help! Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 9, 2009 Share Posted April 9, 2009 Are the two objects actually a Block? or an Xref? or a Group? Quote Link to comment Share on other sites More sharing options...
marlon Posted April 9, 2009 Author Share Posted April 9, 2009 How do I know if it's a Block or an Xref or a Group? Sorry, sort of a newbie here. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 9, 2009 Share Posted April 9, 2009 Click on the object to select it, then right click and choose Properties from the pop up menu. This will open a dialog which will tell you what you have selected and give you information about it. Quote Link to comment Share on other sites More sharing options...
marlon Posted April 9, 2009 Author Share Posted April 9, 2009 the drop down list at the very top says 3D Solid...is that what you're referring to? Quote Link to comment Share on other sites More sharing options...
marlon Posted April 9, 2009 Author Share Posted April 9, 2009 also, it doesn't say 3D Solid (2) , that means the two objects are always selected as one. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 9, 2009 Share Posted April 9, 2009 also, it doesn't say 3D Solid (2) Ok, that was going to be my next question. So did you create this drawing? The two objects could have been Unioned together. Even if they are not touching, they can still be combined. Could this be what happened? Quote Link to comment Share on other sites More sharing options...
marlon Posted April 9, 2009 Author Share Posted April 9, 2009 Yes I think that's it! I tried EXPLODE, but that turned the 3d objects into regions. I can't have that. any suggestions? Quote Link to comment Share on other sites More sharing options...
fuccaro Posted April 9, 2009 Share Posted April 9, 2009 SOLIDEDIT>Body>seParate it doesn't work? Quote Link to comment Share on other sites More sharing options...
marlon Posted April 9, 2009 Author Share Posted April 9, 2009 It worked fuccaro! I was just about to use SLICE, i think that would work too, but your solution was more 'professional'. Thanks guys! Quote Link to comment Share on other sites More sharing options...
fuccaro Posted April 9, 2009 Share Posted April 9, 2009 You can use slice or boolean operations as long as there are only two or few parts involved. For more complicated cases the solidedit is the way to go. Glad to read you solved it. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 9, 2009 Share Posted April 9, 2009 I too would have suggested first trying to use the SEPARATE command. The condition you describe is quite common when a single solid object has a portion of its geometry removed via the subtract command and the result "appears" to be two individual objects when in reality AutoCAD still treats them as one. Quote Link to comment Share on other sites More sharing options...
