So I have been using this LISP routine for close to 20 years. It was working in 2024. This last month I am getting this error:
_DNOTE ; error: quit / exit abort
This is the script:
<;Tip1566A:  DIMNOTE.LSP   Dimension Notes   (c)1999, Mike Lapinski
;reformatted, verified with R2000/R14/R13
;clarified command prompts
(defun DN_SHOWNOTE (/ LNUM LNOTE)
   (set_tile "error" "")
   (setq LNUM  (get_tile "lb_notes")
         LNOTE (nth (atoi LNUM) DM_NOTES)
   ) ;_ end of setq
   (set_tile "eb_note" LNOTE)
) ;_ end of defun
;; Function: DN_PlaceNote
;; Purpose:  If valid note is input, close dialog box
(defun DN_PLACENOTE ()
   (setq DN_MODIFIER (strcase (get_tile "eb_note")))
   (if (= DN_MODIFIER " ")
      (set_tile "error" "Invalid note string")
      (done_dialog 1)
   ) ;_ end of if
) ;_ end of defun
;; Function: DN_AppendNote
;; Purpose:  Append note to selected dimension entity
(defun DN_APPENDDIM (VAL PLACEMENT / ENT DVAL)
   (setq ENT (car (entsel "\nSelect dimension for note: ")))
   (while (/= "DIMENSION" (cdr (assoc 0 (entget ENT))))
      (princ "\nSelected entity is not a DIMENSION.")
   ) ;while
   (setq ENT  (entget ENT)
         DVAL (cdr (assoc 1 ENT))
   ) ;_ end of setq
   (if (= DVAL "")
      (setq DVAL "<>")
   ) ;_ end of if
   (if (= PLACEMENT 1) ;above line
      (setq VAL (strcat DVAL " " VAL))
      (progn (if (wcmatch DVAL "*\\X*")
                (setq VAL (strcat DVAL "\\P" VAL))
                (setq VAL (strcat DVAL "\\X" VAL))
             ) ;_ end of if
      ) ;_ end of progn
   ) ;_ end of if
   (entmod (subst (cons 1 VAL) (assoc 1 ENT) ENT))
) ;_ end of defun
;; Main Function - Dimension NOTE
(defun C:DNOTE (/ DCL_ID DM_NOTES DN_ABOVE)
   (setq DCL_ID (load_dialog "dimnote.dcl"))
   (if (not (new_dialog "dimnote" DCL_ID))
      (exit)
   ) ;_ end of if
   (setq DM_NOTES '("CLR." "CLEAR" "M.O." "MIN." "MAX." "REF." "R.O." "TYP." "TYPICAL"
                    "V.I.F." "VERIFY IN FIELD" "LEASE LINE" "MTL. STUDS" "+ or -" "A.C.T" "HVAC"
                                   "DECK ABV." "CONC. BEAM" "VARIES" "CLG. HT." "MEAN ROOF HT.")
         DN_ABOVE 0
   ) ;_ end of setq
   (set_tile "eb_note" "TYP.")
   (set_tile "dn_below" "1") ; Set as default
   (start_list "lb_notes")
   (mapcar 'add_list DM_NOTES)
   (end_list)
   (set_tile "lb_notes" "7")
   (action_tile "lb_notes" "(DN_ShowNote)")
   (action_tile "dn_above" "(setq dn_above 1)")
   (action_tile "dn_below" "(setq dn_above 0)")
   (action_tile "accept" "(DN_PlaceNote)")
   (action_tile "cancel" "(done_dialog 0)")
   (if (eq (start_dialog) 1)
      (DN_APPENDDIM DN_MODIFIER DN_ABOVE)
   ) ;_ end of if
   (unload_dialog DCL_ID)
) ;_ end of defun
(princ "\n         Dimnote loaded...  Start command by typing   DNOTE ")
(princ)>
Any help would greatly appreciated
Edited by SLW210
Added Code Tags!
The Admin will ask you use the <> when posting code, so please fix.
You are loading a dcl which you have not provided, you can edit post, attach the dcl.
When you say  not working that is not enough, do you get error message or what ?
just googled 'tip1566'
make sure that this line (setq DCL_ID (load_dialog "dimnote.dcl")) is used in the right way :
- either dimnote.dcl lives in one of your support paths else add complete path to name in above line.
- if you use the one from zipfile rename it to dimnote.dcl if you use your own lisp file because it looks for this name else it uses (exit)
I would prefere to use (progn (alert "unable to load dialog")(exit))
you can't have enough / too much alert (or princ) functions in your apps to find out where somethings has gone wrong (usually , where you messed up)
Tip1566.zip
Edited by rlx
