Just a quick question - is there a way to cycle through a variant, as one does with a collection using vlax-for?
I thought maybe:
(foreach x  (vlax-safearray->list
             (vlax-variant-value <Variant>))
           ;;  Do Something  ;;
But I just wondered if this was the only way to perform this type of operation.
Thanks
Lee
lee, that's the easier way for manipulating variants which is by converting it directly to a list thru (vlax-safearray->list) . The other way could be writing a routine which require some coding:
1. converting variant to safearray(vlax-variant-value),
2. getting its dimension(vlax-safearray-get-dim),
3. getting the bounds (vlax-safearray-get-l-bound/u-bound) for each dimension,
4. and using (vlax-safearray-get-element) for each element in the bound
Ahh, I understand Wizman - just extracting each element individually.
I just thought there might be a way to cycle through the elements directly, without having to go through the conversion - but thanks for the suggestion it is much appreciated :)
Lee
