GE13579 Posted April 16, 2009 Posted April 16, 2009 Yep it's a system variable as far as I'm aware? I would have thought the VIEWRES command would do as well? NBC??? Quote
NBC Posted April 16, 2009 Posted April 16, 2009 Viewres is a variable as well as a command - seems to be an anomaly if you ask me. However, setting it within the OPTIONS as described above by GE, is exactly as typing VIEWRES at the commandline. It will not set it for every drawing you open from that point on. Quote
GE13579 Posted April 16, 2009 Posted April 16, 2009 Hmmm does that mean that someone set this prior to installing here? I gotta watch what I say I'm sure all my drawings open with VIEWRES at 20000. Cheers for the clarification NBC and apologies Arizona. Quote
Lee Mac Posted April 16, 2009 Posted April 16, 2009 Also, check that the shademode is set to 2Dwireframe - could be causing an issue. Quote
