Alignment Unhandled Access Violation Error
Hi everyone,
I'm in bit of a trouble now, I have a drawing with 8 alignments, one single surface and a profile view created for each alignment with EG and FG lines created in them.
The problem is that suddenly I wasn't able to modify the alignments anymore, I got this "Unhandled Access Violation Error" followed by some numbers, and a civil shut down. "Audit" doesn't help, "purge" neither and if i want to copy everything to a clean new sheet then I also get a fatal error. The same thing with this drawing happens on other PC's as well, plus I can edit surfaces and profile views, so the problem is only in the alignments. I can explode them, delete them, but it takes some effort rebuilding everything from scratch once more.
Any help would be much appreciated.
Did you try an export/import landxml into a new blank dwg created from your template?
Hi, thanks for the reply, I tried to export/import it to/from landxml like you suggested, the alignments seem to work ok then except that I have to redo the profiles, since as soon as I delete the old corrupted alignments the profile views disappear as well.
