SuperCAD Posted April 15, 2009 Posted April 15, 2009 I'm using the SECTIONPLANE command to create elevations of a solid (I know, FLATSHOT is an option too), but when the block is inserted, it shows the image as a mirror of what it should be (i.e. objects that "should" be on the right, are on the left). The command gives me the following: Select face or any point to locate section line or [Draw section/Orthographic]: I selected Orthographic. Align section to: [Front/bAck/Top/Bottom/Left/Right]: I selected Left. Now, when I create the 2D section/elevation what should be the left elevation looks like the right elevation. I've tried rotating the section plane, moving it, flipping it and nothing is working. What am I doing wrong here? Quote
Patrick Hughes Posted April 16, 2009 Posted April 16, 2009 I'm on r14 so I don't have sectionplane available, but this sounds like it might be UCS related. Check your UCS before doing the sectionplane. Quote
