Prime Posted January 16, 2008 Posted January 16, 2008 Open the file containing those Light Wieght polylines. Then just for a minute create a new surface in your Prospector. Add all of those polylines to the surface as one giant group of breaklines. Then select that breakline group name in Prospector>>Rt Click and Select Properties, the Panorama will appear. Use CTRL+A to select all entries, Rt Click and select Copy to Clipboard. Paste into word or excel to groom the file of the breakline names, formatting, to turn it into a clean ascii file, user database file. Quote
maiyourathaan Posted January 10, 2013 Posted January 10, 2013 i need to extrac xyz from my Auto cad 2007, i want to give me a step by step procedure to do it Quote
chiefrenzo Posted February 5, 2013 Posted February 5, 2013 for the life of me i cannot find the "create points" box you show. Where is that located? Found it. Expand the create points box (blue chevron on right side - circled in red) and under "prompt for descriptions" set it to None. Then initiate your command to create points on poly.If you use SLW210's method you can just copy and paste the coords from the command window. Quote
SLW210 Posted February 5, 2013 Posted February 5, 2013 for the life of me i cannot find the "create points" box you show. Where is that located? That information was for Land Desktop and/or Civil 3D. Quote
chiefrenzo Posted February 6, 2013 Posted February 6, 2013 ok, no wonder i couldn't find anything like that. I had to resort to extracting the data from a DXF file. I put the polyline in a separate file, then exported it to DXF. The DXF is an ascii file, fortunately not too hard to figure out where the coordinates are. For anyone who wants it, here is a program written in BASIC that will extract all the XYZ coordinates in every polyline in a DXF file, and write each polyline data into a separate file. This is written in PowerBasic, but is pretty representative of any Basic language. #COMPILE EXE #DIM ALL FUNCTION PBMAIN () AS LONG LOCAL junk AS STRING LOCAL x,y,z AS SINGLE LOCAL filecount AS SINGLE filecount = 0 LOCAL savename AS STRING savename = "c:\ljc\velocity" OPEN "c:ljc\velocityeltoro.dxf" FOR INPUT AS #1 'name of the DXF file with the polylines WHILE NOT EOF(#1) LINE INPUT #1, junk IF junk$ = "AcDb2dPolyline" THEN 'looking for the polyline tag inside the file filecount = filecount + 1 OPEN savename + TRIM$(STR$(filecount)) + ".txt" FOR OUTPUT AS #2 'open a new output file for each polyline WHILE NOT EOF(#1) LINE INPUT #1, junk IF junk = "SEQEND" THEN 'if found the end of a polyline, close this file and look for the next CLOSE #2 GOTO done_with_that_polyline END IF IF junk = "AcDb2dVertex" THEN 'found a vertex within the polyline LINE INPUT #1, junk 'marker = 10 for x LINE INPUT #1, junk 'read x x = VAL(junk) LINE INPUT #1, junk 'marker = 20 LINE INPUT #1, junk 'read y y = VAL(junk) LINE INPUT #1, junk 'marker = 30 LINE INPUT #1, junk 'read z z = VAL(junk) PRINT filecount,x,y,z PRINT #2,filecount,CHR$(9),x,CHR$(9),y,CHR$(9),z 'write xyz to the file END IF WEND END IF done_with_that_polyline: 'go find the next polyline WEND CLOSE #1 CLOSE #2 END FUNCTION That information was for Land Desktop and/or Civil 3D. Quote
SLW210 Posted February 6, 2013 Posted February 6, 2013 Good solution to go around LT's limitations, as well as a good solution for full AutoCAD. Quote
