hello all:
I use a code that aligns a text with a line
The problem is that sometimes I need to rotate the text 180 degrees
I would like to modify this routine
so that when you rotate the text you have the option to rotate it 180 or exit if it is the correct angle
here code.
defun c:TY (/)
   (setq old_err *error*)
  (defun *error* (a /)
    (princ "")
    (setq *error* old_err)
  (setvar "cmdecho" 0)
  (vl-load-com)
  (setq	VlaObjLine
	 (vlax-ename->vla-object
	   (car (entsel "Selecciona una linea : "))
  (setq LinAngle (vla-get-Angle VlaObjLine))
  (while (setq VlaObjText
		  (car (entsel "Selecciona un texto : "))
    (vla-put-Rotation VlaObjText LinAngle)
    (vlax-release-object VlaObjText)
  (vlax-release-object VlaObjLine)
  (setvar "cmdecho" 1)
  );fin defun
thanks
Hi
Maybe it's better to solve the problem from scratch. Below '(setq LinAngle...)' write:
(if (and (< LinAngle 4.71239) (> LinAngle 1.5708))
  (setq LinAngle (+ LinAngle PI))
Note: It doesn't matter if 'LinAngle' exceeds 2PI, AutoCAD takes care of subtracting the excess
  • Thanks 1
But if for some reason you want to keep the current behavior and change the orientation at the end, the code could be like this:
(defun c:TY (/)
    (princ "")
  (vl-load-com)
  (setq	VlaObjLine
;;;  (if (and (< LinAngle 4.71239) (> LinAngle 1.5708))
;;;    (setq LinAngle (+ LinAngle PI))
    (while (not (member (setq cambiar? (strcase (getstring "\n¿Rotar el texto?  <No>/Si: "))) '("" "N" "NO" "S" "SI")))
      (princ "\nOpcion seleccionada no valida. Repite, por favor...")
    (if (member cambiar? '("S" "SI"))
      (vla-put-Rotation VlaObjText (+ LinAngle PI))
Edited by GLAVCVS
  • Thanks 1
