from pyrx import Rx, Ge, Gi, Gs, Db, Ap, Ed, Ax
import traceback
import wx  # wxPython
import openpyxl as xl
from openpyxl.drawing.image import Image as xlImage
from openpyxl.utils.cell import get_column_letter
@Ap.Command()
def doit():
    try:
        db = Db.curDb()
        ps, id, _ = Ed.Editor.entSel("\nSelect a table: ", Db.Table.desc())
        if ps != Ed.PromptStatus.eOk:
            raise RuntimeError("Selection Error! {}: ".format(ps))
        wb = xl.Workbook()
        ws = wb.active
        table = Db.Table(id)
        opts = Db.TableIteratorOption.kTableIteratorSkipMerged
        for cell in table.cells(opts):
            if table.cellType(cell.row, cell.column) == Db.CellType.kBlockCell:
                blk = table.blockTableRecordId(cell.row, cell.column)
                img: wx.Image = Gs.Core.getBlockImage(blk, 64, 64, 1.0, [0, 0, 0])
                img.SetMaskColour(0, 0, 0)
                img.SetMask(True)
                imgpath = "E:\\temp\\Icons\\{}.png".format(blk.handle())
                img.SaveFile(imgpath, wx.BITMAP_TYPE_PNG)
                xlimg = xlImage(imgpath)
                xlimg.width = 64
                xlimg.height = 64
                cellref = "{}{}".format(get_column_letter(cell.column + 1), cell.row + 1)
                ws.add_image(xlimg, cellref)
            else:
                ws.cell(
                    row=cell.row + 1,
                    column=cell.column + 1,
                    value=table.textString(cell.row, cell.column),
        wb.save("E:\\temp\\logo.xlsx")
    except Exception as err:
        traceback.print_exception(err)
  • Thanks 1
import traceback
@Ap.Command()
def doit():
    try:
        db = Db.curDb()
        wb = xl.Workbook()
        ws = wb.active
                img.SetMask(True)
                xlimg.width = 64
                xlimg.height = 64
            else:
                ws.cell(
                    row=cell.row + 1,
YES!!!
quite impressive i must say.
now,
how do I run this code (Python, right?)  in autocad\bricscad?......😁😵‍💫
thanks,
Edited by aridzv
Sorry, I noticed your running BricsCAD 2021? If so, I’m sorry to say only v24-v25 is supported.
Or maybe you forgot to update your profile?
1, head over to https://github.com/CEXT-Dan/PyRx?tab=readme-ov-file#installation and have look at the project
2, Download and install 3.12.10 x64 from https://www.python.org/downloads/windows/  (all users is NOT checked, and PATH is checked)
3, Open up PowerShell and type “pip install cad-pyrx” without the quotes.
4, in BricsCAD, type “appload”, navigate to:  “AppData\Programs\Python\Python312\Lib\site-packages\pyrx\RxLoaderV25.0.brx”
5, Make sure it’s loaded, type “pyload” at the bricscad prompt
6, if the load dialog box shows, then were successful so far
7, close bricscad
8, back in powershell type  “pip install openpyxl” , this will install the excel library.
9, copy paste the sample code above into a file into a text file, “myfirstmodule.py”
10, using a text editor, edit the paths in the sample, maybe rename the “doit” command
11, open BricsCAD, type in “pyload”, load your module, run your new command
If you get this far, you might want to grab a python editor like VsCode and install the python plugins
  • Like 2
@Danielm103
I'm working with V25.2.05.
thanks for the guide.
I'll work on it and if I'll have questions I'll be back...😁
thanks!!
aridzv
@Danielm103
Hi.
after doing all I get this massege after running "doit":
 File "c:\users\aridzv\appdata\local\programs\python\python312\Lib\site-packages\openpyxl\drawing\image.py", line 13, in _import_image
    raise ImportError('You must install Pillow to fetch image objects')
ImportError: You must install Pillow to fetch image objects
also see attached screenshot.
what am I doing wrong?
aridzv.
pip install pillow
you will need to restart bricscad
Edited by Danielm103
I also noticed I had a BricsCAD support request
SR 180584 AcGsView::getSnapShot does not pickup shademode, so the icons will come out wireframe.
But, I made a work around.. I'll make a build
ignore.
changed the path in the code
Edited by aridzv
ignore....
Edited by aridzv
you missed, 10, edit the paths
Quote
just make a folder c:\\temp and do
Quote
imgpath = "C:\\temp\\{}.png".format(blk.handle())
wb.save("C:\\temp\\logo.xlsx")
Replace AppData\Programs\Python\Python312\Lib\site-packages\pyrx\ PyRxV25.0.brx
with this
set the current shademode to realistic before running doit
remove file, will update the package
  • Thanks 1
@Danielm103
ignore...
again...😁
I fixed the path as you wrote.
its working good with shade visual style.
another question:
is it possible to set the rows hight to a value of 60 for example?
edit:
and set the cell alignment to middle-center?
Edited by aridzv
did you create folder(s) did you see my note above?
change the code to something like, make sure the folder exists and you have write permissions
Quote
yes,eventually...
my bad.
 ws.row_dimensions[ cell.row + 1].height = 64  ##add this line
add alignment
import traceback
from openpyxl.styles import Alignment #---------------------
@Ap.Command()
def doit():
    try:
        db = Db.curDb()
        wb = xl.Workbook()
        ws = wb.active
                img.SetMask(True)
                xlimg.width = 64
                xlimg.height = 64
                ws.row_dimensions[ cell.row + 1].height = 60
                currentCell = ws.cell(cell.row + 1,cell.column + 1)#---------------------
                currentCell.alignment = Alignment(horizontal='center',vertical='center')#---------------------
            else:
                ws.cell(
                    row=cell.row + 1,
also, you can change the icon size
#id width, height, zoom, RGB
img: wx.Image = Gs.Core.getBlockImage(id, 64, 64, 1.0, [0, 0, 0])
could be 128 128, you'll need to change the cell size to match
@Danielm103
GREAT!!!
question about autoload the file:
I inserted in to my "on_start.lsp" and "on_doc_load.lsp" files this code:
(SETVAR "FILEDIA" 0)
(command "pyload" "C:\\Users\\AridZv\\AppData\\Roaming\\Bricsys\\BricsCAD\\Lsp\\Python\\TableWimagetoExcel.py")
(SETVAR "FILEDIA" 1)
now,
if I open I file from the "welcome" screen it dosn't load.
if I then open other file it is loading.
any idea on why (probebally...) the "on_start.lsp" don't take effect?
try this,
Make a file pyrx_onload.py
Make sure the file is in a search path, maybe in the same folder as "on_start.lsp" and "on_doc_load.lsp"
guts
from pyrx import Ap
Ap.Application.loadPythonModule(
@Danielm103
for some reason the alignment don't take effect.
the row hight dose.
here is the code that i'm usuing:
import traceback
@Ap.Command()
def doit1():
    try:
        db = Db.curDb()
        wb = xl.Workbook()
        ws = wb.active
                img.SetMask(True)
                xlimg.width = 64
                xlimg.height = 64
            else:
                ws.cell(
                    row=cell.row + 1,
if you could help with the alignment it whould be grate.
thanks,
aridzv.
