aridzv Posted April 19 Posted April 19 @Danielm103 about getting effective *U block name in autocd, try adding this line to my geteffectivenamebr lisp: (setq bname (vla-get-effectivename (vlax-ename->vla-object selblk))) Quote
Danielm103 Posted April 19 Author Posted April 19 getEffectiveNameFromBtrId helper works for AutoCAD, however BricsCAD doesn’t have a direct API to do this for parametric blocks, I’m investigating alternatives. vla-get-effectivename, "EffectiveName~Native" are designed to give us the name from a block reference blk = table.blockTableRecordId(cell.row, cell.column) gives us a Block table record id, not a reference I have a working solution with the help of Bricsys support that should give us what we need, it’s a bit of a kludge though 1 Quote
aridzv Posted April 19 Posted April 19 Thanks!!! hope bricscad support will help. for me at least there is no pressure. Right now we know how to build a table in AutoCAD that contains values that Python knows how to work with. and I do belive bricscad will help. aridzv. 1 Quote
aridzv Posted April 20 Posted April 20 (edited) @Danielm103 I need help with converting the code to work with "xlsxwriter" instand of with "openpyxl" Because I think it will solve the problem of the image aligment in the cells. I started with it, But for starters I think I'm stuck with the "else" statment in row 67. can you please have a look on the code below? thanks, aridzv. #https://www.cadtutor.net/forum/topic/97450-export-table-with-blocks-to-excel-with-python/ from pyrx import Rx, Ge, Gi, Gs, Db, Ap, Ed, Ax import traceback #from openpyxl.drawing.image import Image as xlImage #from openpyxl.utils.cell import get_column_letter #from openpyxl.styles import Alignment import xlsxwriter #import openpyxl as xl import pathlib import ctypes #import wx @Ap.Command() def Py_tablewithimagetoexcelxlswriter(): try: db = Db.curDb() ps, id, _ = Ed.Editor.entSel("\nSelect a table: ", Db.Table.desc()) if ps != Ed.PromptStatus.eOk: raise RuntimeError("Selection Error! {}: ".format(ps)) # paths xlpath = pathlib.Path(db.getFilename()).parent xlname = pathlib.Path(db.getFilename()).stem fpt = "{}\{}.xlsx".format(xlpath, xlname) wb = xlsxwriter.Workbook("hello.xlsx")#create workbook ws = workbook.add_worksheet()#create worksheet in workbook ws.set_default_row(15)#set default row height to 39.6 ws.set_column(2, 2, 15.44)#set columnn B width (where the images will be) to 15.44 cell_format = ws.add_format()# add format cell_format.set_align('center') cell_format.set_align('vcenter') #wb = xl.Workbook() #ws = wb.active table = Db.Table(id) opts = Db.TableIteratorOption.kTableIteratorSkipMerged for cell in table.cells(opts): # format all cells currentCell = ws.cell(cell.row + 1, cell.column + 1) currentCell.alignment = Alignment(horizontal="center", vertical="center") if table.cellType(cell.row, cell.column) == Db.CellType.kBlockCell: blk = table.blockTableRecordId(cell.row, cell.column) bname = getEffectiveNameFromBtrId(blk) img: wx.Image = Gs.Core.getBlockImage(blk, 495, 495, 1.0, [0, 0, 0]) img.SetMaskColour(0, 0, 0) img.SetMask(True) imgpath = "{}/{}.png".format(xlpath, bname)#blk.handle() img.SaveFile(imgpath, wx.BITMAP_TYPE_PNG) xlimg = xlImage(imgpath) xlimg.width = 64 xlimg.height = 64 cellref = "{}{}".format(get_column_letter(cell.column + 1), cell.row + 1) #ws.add_image(xlimg, cellref) ws.set_row(cell.row + 1, 39.6) ws.insert_image(cellref, xlimg, {'x_offset': 0, 'y_offset': 0, 'x_scale': 0.8, 'y_scale': 0.8}) #ws.row_dimensions[cell.row + 1].height = 64 ############################################################################################ else: ws.cell( row=cell.row + 1, column=cell.column + 1, value=table.textString(cell.row, cell.column), ) ############################################################################################ #nested function def as_text(value): if value is None: return "" return str(value) # make another pass to set the widths + a little extra for column_cells in ws.columns: length = max(len(as_text(cell.value)) for cell in column_cells) ws.column_dimensions[column_cells[0].column_letter].width = length * 1.25 #wb.save("{}/{}.xlsx".format(xlpath, xlname)) wb.close() ctypes.windll.user32.MessageBoxW(0, fpt , "Files Saved", 1) except Exception as err: traceback.print_exception(err) def getEffectiveNameFromBtrId(btrid: Db.ObjectId): rec = Db.BlockTableRecord(btrid) if rec.isAnonymous() and rec.hasXData("AcDbBlockRepBTag"): for dfx, val in rec.xData("AcDbBlockRepBTag"): if dfx == 1005: hnd = Db.Handle(val) dynid = rec.database().tryGetObjectId(False, hnd) dynrec = Db.BlockTableRecord(dynid) return dynrec.getName() return rec.getName() Edited April 20 by aridzv Quote
Danielm103 Posted April 20 Author Posted April 20 I’ve never used xlsxwriter, here’s my shot but I don’t see that it formats the image better from pyrx import Rx, Ge, Gi, Gs, Db, Ap, Ed, Ax, Brx import traceback import pathlib import xlsxwriter import wx @Ap.Command() def doit(): try: db = Db.curDb() ps, id, _ = Ed.Editor.entSel("\nSelect a table: ", Db.Table.desc()) if ps != Ed.PromptStatus.eOk: raise RuntimeError("Selection Error! {}: ".format(ps)) xlpath = pathlib.Path(db.getFilename()).parent xlname = pathlib.Path(db.getFilename()).stem fpt = "{}/{}.xlsx".format(xlpath, xlname) wb = xlsxwriter.Workbook(fpt) # create workbook ws = wb.add_worksheet() # create worksheet in workbook ws.set_default_row(40) # set default row height to 39.6 cell_format = wb.add_format() # add format cell_format.set_align("center") cell_format.set_align("vcenter") table = Db.Table(id) opts = Db.TableIteratorOption.kTableIteratorSkipMerged for cell in table.cells(opts): if table.cellType(cell.row, cell.column) == Db.CellType.kBlockCell: ws.set_column(cell.column,cell.column, 15.44, cell_format) blk = table.blockTableRecordId(cell.row, cell.column) bname = getEffectiveNameFromBtrId(blk) img: wx.Image = Gs.Core.getBlockImage(blk, 64, 64, 1.0, [0, 0, 0]) img.SetMaskColour(0, 0, 0) img.SetMask(True) imgpath = "{}/{}.png".format(xlpath, bname) img.SaveFile(imgpath, wx.BITMAP_TYPE_PNG) ws.insert_image( cell.row, cell.column, imgpath, {"x_offset": 0, "y_offset": 0, "x_scale": 0.8, "y_scale": 0.8}, ) else: val = table.textString(cell.row, cell.column) #try to get a text width w, h =table.calcTextExtents(val,table.textStyle(cell.row, cell.column)) ws.set_column(cell.column,cell.column, w, cell_format) ws.write(cell.row, cell.column, table.textString(cell.row, cell.column)) wb.close() except Exception as err: traceback.print_exception(err) def getEffectiveNameFromBtrId(btrid: Db.ObjectId): rec = Db.BlockTableRecord(btrid) if rec.isAnonymous(): ids = rec.getBlockReferenceIds() if len(ids) > 0 and Brx.DbProperties.isValid(ids[0], "EffectiveName~Native"): val = Brx.DbProperties.getValue(ids[0], "EffectiveName~Native") return val.getString() return rec.getName() Quote
aridzv Posted April 20 Posted April 20 37 minutes ago, Danielm103 said: I’ve never used xlsxwriter, here’s my shot but I don’t see that it formats the image better yes, it dosn't... thanks any way!! aridzv. Quote
Danielm103 Posted April 20 Author Posted April 20 (edited) It does seem to give more control, I would consider renaming the column BLOCK PREVIWE, to something shorter, or less than the size of the icon, maybe just IMAGE, or BLOCK Edited April 20 by Danielm103 1 Quote
aridzv Posted April 21 Posted April 21 @Danielm103 Can you explain this line to me? I did a search on "Python xlsxwriter table.calcTextExtents" but didn't find anything.... w, h =table.calcTextExtents(val,table.textStyle(cell.row, cell.column)) thanks... Quote
Danielm103 Posted April 21 Author Posted April 21 4 hours ago, aridzv said: @Danielm103 Can you explain this line to me? I did a search on "Python xlsxwriter table.calcTextExtents" but didn't find anything.... w, h =table.calcTextExtents(val,table.textStyle(cell.row, cell.column)) thanks... It’s a helper method in PyRx to help build tables. The idea is, when you need to build a table inside CAD, but you don’t know what to set the column width to. w, h = table.calcTextExtents(“This is a long text item”, TextStyleId) will compute the actual size of the text in drawing units it may not be applicable in the context since excel has different units Quote
aridzv Posted April 21 Posted April 21 (edited) @Danielm103 1. about aligning the image to the center of the cell: I changed the X offset value (A process of trial and error and depends on the length of the header text): {"x_offset": 35, "y_offset": 0, "x_scale": 0.8, "y_scale": 0.8} 2. the first column was invisible because "val" for those cells was empty after the header's row and those tow lines return empty string after the first row which set the column width to 0: w, h =table.calcTextExtents(val,table.textStyle(cell.row, cell.column)) ws.set_column(cell.column,cell.column, w, cell_format) so I did this change with "autofit": else: #val = table.textString(cell.row, cell.column) #try to get a text width #w, h =table.calcTextExtents(val,table.textStyle(cell.row, cell.column)) ws.set_column(cell.column,cell.column, 1, cell_format)#minimum width,autofit wil set at the end ws.write(cell.row, cell.column, table.textString(cell.row, cell.column)) ws.autofit() wb.close() here is the final code I'm using: #https://www.cadtutor.net/forum/topic/97450-export-table-with-blocks-to-excel-with-python/ from pyrx import Rx, Ge, Gi, Gs, Db, Ap, Ed, Ax, Brx import traceback import pathlib import xlsxwriter import ctypes import wx @Ap.Command() def Py_tablewithimagetoexcel_xlsxwriter(): try: db = Db.curDb() ps, id, _ = Ed.Editor.entSel("\nSelect a table: ", Db.Table.desc()) if ps != Ed.PromptStatus.eOk: raise RuntimeError("Selection Error! {}: ".format(ps)) xlpath = pathlib.Path(db.getFilename()).parent xlname = pathlib.Path(db.getFilename()).stem fpt = "{}/{}.xlsx".format(xlpath, xlname) wb = xlsxwriter.Workbook(fpt) # create workbook ws = wb.add_worksheet() # create worksheet in workbook ws.set_default_row(40) # set default row height to 39.6 cell_format = wb.add_format() # add format cell_format.set_align("center") cell_format.set_align("vcenter") table = Db.Table(id) opts = Db.TableIteratorOption.kTableIteratorSkipMerged for cell in table.cells(opts): if table.cellType(cell.row, cell.column) == Db.CellType.kBlockCell: ws.set_column(cell.column,cell.column, 15.44, cell_format) blk = table.blockTableRecordId(cell.row, cell.column) bname = getEffectiveNameFromBtrId(blk) img: wx.Image = Gs.Core.getBlockImage(blk, 64, 64, 1.0, [0, 0, 0]) img.SetMaskColour(0, 0, 0) img.SetMask(True) imgpath = "{}/{}.png".format(xlpath, bname) img.SaveFile(imgpath, wx.BITMAP_TYPE_PNG) ws.insert_image( cell.row, cell.column, imgpath, {"x_offset": 35, "y_offset": 0, "x_scale": 0.8, "y_scale": 0.8}, ) else: #val = table.textString(cell.row, cell.column) #try to get a text width #w, h =table.calcTextExtents(val,table.textStyle(cell.row, cell.column)) ws.set_column(cell.column,cell.column, 1, cell_format)#keep format,set minimum width,autofit will set at the end ws.write(cell.row, cell.column, table.textString(cell.row, cell.column)) ws.autofit() wb.close() ctypes.windll.user32.MessageBoxW(0, fpt , "Files Saved", 1) except Exception as err: traceback.print_exception(err) def getEffectiveNameFromBtrId(btrid: Db.ObjectId): rec = Db.BlockTableRecord(btrid) if rec.isAnonymous(): ids = rec.getBlockReferenceIds() if len(ids) > 0 and Brx.DbProperties.isValid(ids[0], "EffectiveName~Native"): val = Brx.DbProperties.getValue(ids[0], "EffectiveName~Native") return val.getString() return rec.getName() Thanks for all your help!! aridzv. Edited April 21 by aridzv 1 Quote
Danielm103 Posted April 21 Author Posted April 21 Nice! Autofit to the rescue! Note that PyRx has a full GUI in wxPython (wx), so you can use that instead of ctypes if you want. Then there’s also alert from pyrx import Rx, Ge, Gi, Gs, Db, Ap, Ed, Ax, Brx import traceback import wx @Ap.Command() def doit(): try: wx.MessageBox("Now you have done it") Ed.Core.alert("Now you have done it") except Exception as err: traceback.print_exception(err) Welcome to Python 1 Quote
aridzv Posted April 21 Posted April 21 (edited) Thanks question about what needed to improt. how do I know what to import from PyRx? what do all of the modules in this line do (except of brx of course) from pyrx import Rx, Ge, Gi, Gs, Db, Ap, Ed, Ax, Brx thanks, aridzv. Edited April 21 by aridzv Quote
Danielm103 Posted April 21 Author Posted April 21 You can thing of those as name spaces of ObjectARX. Rx = AcRx, the most base classes for all AutoCAD objects Ge = AcGe, Geometry classes, Points, Vectors, Curves Gi = AcGi , has the class AcGiDrawable, mostly responsible for drawing entities on your screen Gs = AcGs, Graphics system, access to drawing devices and of course getBlockImage Ap = Application level stuff such as the document manager Db = AcDb, the database (.DWG) Ed = AcEd, Editor, selection sets, entsel, getPoint Ax = all of the ActiveX stuff Br = AcBr, access to 3d geometry Brx = stuff specific to BricsCAD. there’s also BrxBim and BrxCv They are all in PyRx, and are loaded in the ARX, so its ok to just include them all Also the .NET documentation is relevant, see Unmanaged to Managed Class Mappings https://help.autodesk.com/view/OARX/2024/ENU/?guid=GUID-390A47DB-77AF-433A-994C-2AFBBE9996AE 1 Quote
