aridzv Posted May 4 Posted May 4 (edited) Hi. How do I get the varaible name that holds the resault of "max" function? Example: (setq var1 1) (setq var2 8) (setq var3 2) (setq lst (list var1 var2 var3)) (setq rsltmx (apply 'max lst)) ;;the return is 8 ;;I need to get "var2". I'm using this: (setq i 1) (foreach cnx lst (if (= cnx rsltmx) (progn (setq titlever (STRCAT "VAR" (rtos i 2 0))) (setq ix i) );progn );if (setq i (1+ i)) );foreach This requires that all variables have the same prefix and end with consecutive numbers. I'm looking for a more "direct" way that will not depends on fixing the names of the variables and their position in the list by their suffix. any ideas? thanks, aridzv. Edited May 4 by aridzv Quote
GLAVCVS Posted May 4 Posted May 4 (edited) Hi ' (setq var (max var1 var2 var3... varn)) ' Edited May 4 by GLAVCVS Quote
aridzv Posted May 4 Author Posted May 4 @GLAVCVS it gives the max value, not the var name that holds that value... thanks, aridzv Quote
GLAVCVS Posted May 4 Posted May 4 (nth (vl-position (max var1 var2 var3 var4) (list var1 var2 var3 var4) (list "var1" "var2" "var3" "var4")) This is one of the possible ways 1 Quote
GLAVCVS Posted May 4 Posted May 4 Another way... (strcat "var" (itoa (1+ (vl-position (max var1 var2 var3 var4) (list var1 var2 var3 var4)))) Quote
aridzv Posted May 4 Author Posted May 4 (edited) @GLAVCVS Thanks!! your first one worked. here: (setq as 1) (setq df 8) (setq io 3) (setq varx (nth (vl-position (max as df io) (list as df io)) (list "as" "df" "io")))) (The second is the same principle as my function) thanks, aridzv. Edited May 4 by aridzv Quote
