CAD2005 Posted May 7 Posted May 7 (edited) Hi everybody. I found this lisp on the forum This lisp is for Sum text, but this lisp only add interger part please review lisp and correct the decimal , example : 2000,35 + 1000,55 = 3000,90 thank you for your help (defun C:STX (/ cpent elist en ip newtxt pt ss sum sumtxt txt) (princ "\n\t\t>>> Select text to get summ >>>") (if ;;select texts/mtexts on screen : (setq ss (ssget '((0 . "*TEXT")))) ;; if selected then : (progn ;; store the first text entity for using 'em further : (setq cpent (ssname ss 0)) ;; set initial sum to zero : (setq sum 0.) ;; loop trough selected texts/mtexts : (while ;; get the first text in selection : (setq en (ssname ss 0)) ;; get entity list of them : (setq elist (entget en)) ;; get the textstring by key 1 from entity list : (setq txt (cdr (assoc 1 elist))) ;; create output string : (setq sumtxt ;; concatenate strings : (strcat ;; convert digits to string : (rtos ;; add to summ the digital value of text : (setq sum (+ (atof txt) sum)) ;; 2 is for metric units (3 for engineering) : 2 ;; set precision by current : (getvar "dimdec"))) ) ;; delete entity from selection set : (ssdel en ss) ) ;; display message in the command line: (princ (strcat "\nSumm=" sumtxt)) (setq pt (getpoint "\nSpecify the new text location: ")) ;; get the insertion point of stored entity : (setq ip (cdr (assoc 10 (entget cpent)))) ;; copy text entity to the new destination point : (command "_copy" cpent "" ip pt) ;; get the last created entity : (setq newtxt (entlast)) ;; get entity list of them : (setq elist (entget newtxt)) ;; modify entity list with new text string : (entmod (subst (cons 1 sumtxt)(assoc 1 elist) elist)) ;; update changes : (entupd newtxt) ) ) (princ) ) (princ "\nStart command with STX...") (princ) Edited May 7 by SLW210 Added Code Tags!! Quote
Emmanuel Delay Posted May 7 Posted May 7 These are not considered numbers: 2000,35 + 1000,55 = 3000,90 These are considered numbers: 2000.35 + 1000.55 = 3000.90 Anyway, A added 2 commands. STXC if you use commas as the decimal point. STXP if you use fullstop character ( "." ) as the decimal point. (vl-load-com) (setq use_comma_as_decimal_point nil) ;; With comma (defun C:STXC ( / ) (setq use_comma_as_decimal_point T) (C:STX) ) ;; With fullstop character (defun C:STXP ( / ) (setq use_comma_as_decimal_point nil) (C:STX) ) (defun C:STX (/ cpent elist en ip newtxt pt ss sum sumtxt txt) (princ "\n\t\t>>> Select text to get summ >>>") (if ;;select texts/mtexts on screen : (setq ss (ssget '((0 . "*TEXT")))) ;; if selected then : (progn ;; store the first text entity for using 'em further : (setq cpent (ssname ss 0)) ;; set initial sum to zero : (setq sum 0.) ;; loop trough selected texts/mtexts : (while ;; get the first text in selection : (setq en (ssname ss 0)) ;; get entity list of them : (setq elist (entget en)) ;; get the textstring by key 1 from entity list : (setq txt (cdr (assoc 1 elist))) (if use_comma_as_decimal_point ;; replace comma by fullstop (setq txt (vl-string-subst "." "," txt)) ) ;; create output string : (setq sumtxt ;; concatenate strings : (strcat ;; convert digits to string : (rtos ;; add to summ the digital value of text : (setq sum (+ (atof txt) sum)) ;; 2 is for metric units (3 for engineering) : 2 ;; set precision by current : (getvar "dimdec") ) ) ) ;; delete entity from selection set : (ssdel en ss) ) ;; display message in the command line: (princ (strcat "\nSumm=" sumtxt)) (setq pt (getpoint "\nSpecify the new text location: ")) ;; get the insertion point of stored entity : (setq ip (cdr (assoc 10 (entget cpent)))) ;; copy text entity to the new destination point : (command "_copy" cpent "" ip pt) ;; get the last created entity : (setq newtxt (entlast)) ;; get entity list of them : (setq elist (entget newtxt)) (if use_comma_as_decimal_point ;; replace fullstop by comma (setq sumtxt (vl-string-subst "," "." sumtxt)) ) ;; modify entity list with new text string : (entmod (subst (cons 1 sumtxt)(assoc 1 elist) elist)) ;; update changes : (entupd newtxt) ) ) (princ) ) (princ "\nStart command with STX...") (princ) Quote
CAD2005 Posted May 7 Author Posted May 7 Thank you @Emmanuel Delay! but I tried it and it didn't give the odd part. Quote
Emmanuel Delay Posted May 7 Posted May 7 (edited) What this code does: you select TEXT elements. Each TEXT is supposed to only hold a numeric value. Then a sum is made of each of the selected numbers. Then you pick a point where the new TEXT comes, with the summed value. Here's an example sum_texts.lsp.dwg Edited May 7 by Emmanuel Delay Quote
CAD2005 Posted May 7 Author Posted May 7 Thank You very much for this help @Emmanuel Delay thank you . 1 Quote
