Hi.
what is rhigt syntax to use foreach to loop through a selection set created by ssget?
I know how to do it with while but can't get it to work with foreach.
when I use foreach the code skips the foreach loop all together and don't raise any errors.
here is the code with foreach:
(defun c:test (/ minln obj ly sspln i plx)
 (vl-load-com)
 (setq minln (getreal "\nLength and below to delete:"))
 (if (setq sspln (ssget (list (cons 0 "*POLYLINE"))))
      (setq i (1- (sslength sspln)))
      (foreach ent sspln
        (setq ent (vlax-ename->vla-object (ssname sspln i)))
        (if (<= (vla-get-length ent) minln)
          (vla-delete ent)
        (setq i (1- i))
      );foreach
   );progn
  );if
);defun
What is the correct way to use foreach here?
thanks,
aridzv.
Hi
It's not possible to use foreach directly on an sset
You'll need to convert the sset to a list first.
For example:
(vl-remove-if 'listp (mapcar 'cadr (ssnamex sset)))
Edited by GLAVCVS
But I have to ask you: why do you need to do this with foreach?
The function logic seems to be the most appropriate for the task,
but I remembered that it was a problem.
I wanted to know if I was missing something...
Edited by aridzv
Use Repeat for a selection set.
;This works from last to first
(repeat (setq x (sslengh ss))
(setq ent (ssname ss (setq x (1- x))))
;For 1st to last
(setq x -1)
(repeat (sslength ss)
(setq ent (ssname ss (setq x (1+ x))))
a little cleaner then while...
(defun c:delpolybylength (/ minln obj ly sspln i plx)
 (vl-load-com)
 (setq obj (entget (car (entsel "\nSelect Layer Object"))))
 (setq ly (cdr (assoc 8 obj)))
 (if (setq sspln (ssget (list (cons 0 "*POLYLINE") (cons 8 ly))))
      (setq i -1)
      (repeat (sslength sspln)
        (setq plx (vlax-ename->vla-object (ssname sspln (setq i (1+ i)))))
        (if (<= (vla-get-length plx) minln)
          (vla-delete plx)
      );repeat
   );progn
  );if
);defun
43 minutes ago, Lee Mac said:
In this tutorial I describe several methods for iterating over a selection set.
yes,
I read your article.
that is why I didn't went for the ssnamex...
So,
Isn't there a relatively straightforward way to use foreach with selection set?
Edited by aridzv
If there was, I would have included it in my list of examples.
  • Thanks 1
19 hours ago, aridzv said:
yes,
So,
This method is used quite a lot by @ronjonp so search in this forum then you should find many elegant and decent routines by him as I personally like reading his.
  • Thanks 2
