Krish72 Posted May 22, 2025 Posted May 22, 2025 Dear all, Please find attached rebar counting lisp, when loaded getting error message (LOAD "C:/Users/krish/Downloads/Barcount.lsp") Pick top left point for table Cannot invoke (command) from *error* without prior call to (*push-error-using-command*). Converting (command) calls to (command-s) is recommended. @BIGAL Thanks Krishna ReoBarcount2.lsp Numbering lisp Diagram (2).dwg Quote
SLW210 Posted May 22, 2025 Posted May 22, 2025 I have moved your thread to the AutoLISP, Visual LISP & DCL Forum. Please post in the most appropriate forum. Do you have AutoCAD LT or full AutoCAD? You posted in the AutoCAD LT forum. For reference, here is where the LISP came from... Quote
GLAVCVS Posted May 22, 2025 Posted May 22, 2025 @Krish72 Hi Just one question: Are you sure the file you attached and the one in your explanation are the same? Quote
BIGAL Posted May 23, 2025 Posted May 23, 2025 Post the dwg your testing it on. The code was specifically written to suit a sample dwg. Quote
