CivilTechSource Posted May 22, 2025 Posted May 22, 2025 Hi I had a stab at my second lisp wrote from scratch. It works!... but I feel like I created a long winded way and open my self room for error with the layers need to be set 100 correct. I would also like to improve the code so it can loop inserting the block or at least remember the last selections maybe? Any advise on improving or optimizing or critising the lisp is welcomed. Thank you ;; Prompts the user to select through two round of options then based on the selection will set the appropriate layer and insert the block (defun c:LE-Manhole () ;initget sets the options for the user to select (initget 1 "Existing Proposed") ;MHCondition is the variable that stores the user's selection regarding the condition of the manhole (setq MHCondition (getkword "\nSelect an option [Existing/Proposed]: " ) ) ;The cond function checks the user's selection and sets the MHC variable accordingly 0 for Existing and 10 for Proposed (cond ((= MHCondition "Existing") (princ "\nYou selected Existing.") (setq MHC 0)) ((= MHCondition "Proposed") (princ "\nYou selected Proposed.") (setq MHC 10)) (t (princ "\nNo valid option selected.")) ) (princ) ;initget sets the options for the user to select the type of manhole ;MHS is the variable that stores the user's selection regarding the type of manhole (initget 1 "Adoptable Private Highways") (setq MHState (getkword "\nSelect an option [Adoptable/Private/Highways]: " ) ) ;The cond function checks the user's selection and sets the MHS variable accordingly 1 for Adoptable, 2 for Private, and 3 for Highways (cond ((= MHState "Adoptable") (princ "\nYou selected Adoptable.") (setq MHS 1)) ((= MHState "Private") (princ "\nYou selected Private.") (setq MHS 2)) ((= MHState "Highways") (princ "\nYou selected Highways.") (setq MHS 3)) (t (princ "\nNo valid option selected.")) ) (princ) ;Status is the variable that stores the sum of MHC and MHS to determine the final selection ;Existing Public 1 ;Existing Private 2 ;Existing Highways 3 ;Proposed Public 11 ;Proposed Private 12 ;Proposed Highways 13 ;The cond function checks the value of Status and sets the current layer accordingly ;The setvar function sets the current layer to the specified layer based on the user's selection (setq Status (+ MHC MHS)) (cond ((= Status 1) (princ "\nYou selected Existing Public.") (setvar "clayer""-LE-D-SW-Existing Public Sewer")) ((= Status 2) (princ "\nYou selected Existing Private.") (setvar "clayer""-LE-D-SW-Existing Drainage")) ((= Status 3) (princ "\nYou selected Existing Highways.") (setvar "clayer""-LE-D-SW-Existing Highway Drainage")) ((= Status 11) (princ "\nYou selected Proposed Public.") (setvar "clayer""-LE-D-SW-Adoptable Manhole")) ((= Status 12) (princ "\nYou selected Proposed Private.") (setvar "clayer""-LE-D-SW-Private Manhole")) ((= Status 13) (princ "\nYou selected Proposed Highways.") (setvar "clayer""-LE-D-SW-Highway Manhole")) (t (princ "\nNo valid option selected.")) ) (princ) ;Inserts Manhole Block (command "_.-INSERT" "Manhole" (getpoint "\nPick the insertion point for the block: ") "1" "" "") ) Quote
BIGAL Posted May 23, 2025 Posted May 23, 2025 Having to do lots of pits you missed one thing and that manholes often need rotating. Not all manholes are round. We had all sorts of sizes of manholes for street drainage. Are your manholes only 1 size ? Have a look at this also. Multi GETVALS.lsp Pit.lsp Quote
CivilTechSource Posted May 23, 2025 Author Posted May 23, 2025 Hi @BIGAL currently for UK the manholes for new project we specify are circular (the majority). Manholes vary in size and the Manhole Block has a visibility state to cycle through the options (personaly against visibility state, it would have been mode efficient to set up manhole dynamically with geometric constraints https://youtu.be/-4avuPOjmQA?si=lOd7aryeQknXUPfu ) Quote
BIGAL Posted May 23, 2025 Posted May 23, 2025 As part of insert a dynamic block I have a pop up dcl so choose the visibility states, as part of the insert lisp just saves the pick on little arrow and choose. I can post if you want it works with any dynamic block. Quote
Tharwat Posted May 25, 2025 Posted May 25, 2025 Here is my Drainage Manholes Network program that might be of a help or at least gives you ideas on your desired automation program. Drainage Manholes Network Program Quote
DavidP Posted May 26, 2025 Posted May 26, 2025 I would suggest checking if the layer exists and if not I create it first. should populate the TAGS after the insert in case the tags are out of order (happens when users modify blocks) and Instead use Lee Mac's utilities. https://www.lee-mac.com/attributefunctions.html to populate to ensure the correct tag get the corresponding values. For Dynamics look here https://www.lee-mac.com/dynamicblockfunctions.html Another tip would be calling the block with the ".dwg" extension "Manhole.dwg" instead of Manhole (Reason is if the block doesn't exist in the drawing AutoCAD will check inside all the "Support file search paths") And last reset what ever custom parameters you used in the lisp. (things like color, snap modes, current layer and so on.....) ;; Set Attribute Value - Lee Mac ;; Sets the value of the first attribute with the given tag found within the block, if present. ;; blk - [vla] VLA Block Reference Object ;; tag - [str] Attribute TagString ;; val - [str] Attribute Value ;; Returns: [str] Attribute value if successful, else nil. (defun LM:vl-setattributevalue ( blk tag val ) (setq tag (strcase tag)) (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (progn (vla-put-textstring att val) val) ) ) (vlax-invoke blk 'getattributes) ) ) ;; Prompts the user to select through two round of options then based on the selection will set the appropriate layer and insert the block (defun c:LE-Manhole ( / InitialLayer layerName bscale LastEnt blk Tag Value InitialLayer) (setq InitialLayer (getvar 'clayer)) (defun *error* (errmsg) (if (not (wcmatch errmsg "Function cancelled, quit / exit abort, console break")) (princ (strcat "\nError: " errmsg))) (setvar 'CLayer InitialLayer) ) ;initget sets the options for the user to select (initget 1 "Existing Proposed") ;MHCondition is the variable that stores the user's selection regarding the condition of the manhole (setq MHCondition (getkword "\nSelect an option [Existing/Proposed]: " ) ) ;The cond function checks the user's selection and sets the MHC variable accordingly 0 for Existing and 10 for Proposed (cond ((= MHCondition "Existing") (princ "\nYou selected Existing.") (setq MHC 0)) ((= MHCondition "Proposed") (princ "\nYou selected Proposed.") (setq MHC 10)) (t (princ "\nNo valid option selected.")) ) (princ) ;initget sets the options for the user to select the type of manhole ;MHS is the variable that stores the user's selection regarding the type of manhole (initget 1 "Adoptable Private Highways") (setq MHState (getkword "\nSelect an option [Adoptable/Private/Highways]: " ) ) ;The cond function checks the user's selection and sets the MHS variable accordingly 1 for Adoptable, 2 for Private, and 3 for Highways (cond ((= MHState "Adoptable") (princ "\nYou selected Adoptable.") (setq MHS 1)) ((= MHState "Private") (princ "\nYou selected Private.") (setq MHS 2)) ((= MHState "Highways") (princ "\nYou selected Highways.") (setq MHS 3)) (t (princ "\nNo valid option selected.")) ) (princ) ;Status is the variable that stores the sum of MHC and MHS to determine the final selection ;Existing Public 1 ;Existing Private 2 ;Existing Highways 3 ;Proposed Public 11 ;Proposed Private 12 ;Proposed Highways 13 ;The cond function checks the value of Status and sets the current layer accordingly ;The setvar function sets the current layer to the specified layer based on the user's selection (setq Status (+ MHC MHS)) (setq layerName (cond ((= Status 1) (princ "\nYou selected Existing Public.") "-LE-D-SW-Existing Public Sewer" ) ((= Status 2) (princ "\nYou selected Existing Private.") "-LE-D-SW-Existing Drainage") ((= Status 3) (princ "\nYou selected Existing Highways.") "-LE-D-SW-Existing Highway Drainage") ((= Status 11) (princ "\nYou selected Proposed Public.") "-LE-D-SW-Adoptable Manhole") ((= Status 12) (princ "\nYou selected Proposed Private.") "-LE-D-SW-Private Manhole") ((= Status 13) (princ "\nYou selected Proposed Highways.") "-LE-D-SW-Highway Manhole") (t nil) ) ) (if layerName (progn (if (not (tblsearch "LAYER" layerName)) ;; Check if layer exists (command "_LAYER" "M" layerName "C" "1" "" "LType" "Continuous" "" "") ;; Create layer (Red) ) (setq bscale 1 blockName "Manhole.dwg") (command "_.-INSERT" blockName "S" bscale (getpoint "\nPlace Manhole: ") "") (setq LastEnt (entlast)) (setq blk (vlax-ename->vla-object LastEnt)) (setq Tag "TAG1" Value "1.0") (LM:vl-setattributevalue blk Tag Value) (setq Tag "TAG2" Value "2nd Value") (LM:vl-setattributevalue blk Tag Value) ) ) (setvar 'CLayer InitialLayer) ; reset layer back (princ) ) Quote
BIGAL Posted May 26, 2025 Posted May 26, 2025 As suggested I forgot about this , use a check layer. Can be called very simply. ((= MHState "Adoptable") (princ "\nYou selected Adoptable.")(chklayer "Adoptable pits" 1 "Dashed") (setq MHS 1)) checks for the layer name and color. (defun chklay (lay col lt / ) (if (not (tblsearch "LAYER" lay)) (command "-layer" "m" lay "c" col lay "lt" lt lay "") (setvar 'clayer lay) ) (princ) ) 1 Quote
CivilTechSource Posted May 28, 2025 Author Posted May 28, 2025 So basically define a new function. Are the items in the brackets after chklay parameters passed to the function? Quote
DavidP Posted May 28, 2025 Posted May 28, 2025 Correct I would suggest putting commonly used functions like this in a Common.lisp with global access definitions so you can call from any lisp. ;Setup Variables (setq pLayername "My Test Layer" pColor 1 pLineType "Continious") ;Calling the function (chklay pLayername pColor pLineType) Quote
