noyajr Posted May 27, 2025 Posted May 27, 2025 I have polylines and each polyline consists of several segments. i want a lisp to put aligned dimension at the 1st and last segment of those polylines Does anyone have lisp for that ? Quote
BIGAL Posted May 27, 2025 Posted May 27, 2025 Did you google ? There are plenty of examples out there. They usually dimension all segments but they could be simply modified to do only start and end segments. "dimension polylines autocad lisp" 1 Quote
noyajr Posted May 28, 2025 Author Posted May 28, 2025 (edited) for sure i did that, i found lisps that put labels not actual dimensions, or if the lisp put dimension it would be for closed polylines Edited May 28, 2025 by noyajr Quote
BIGAL Posted May 29, 2025 Posted May 29, 2025 Like @SLW210 post a dwg and are the plines always straight segments only ? Can a pline have an arc at the start or end ? Please confirm. The dwg will show us what dim style to use. Quote
