box dcl for lsp routines...
leonucadomi
good day all:
since I already have several routines regarding texts
I find myself in need of creating a dialog box that allows me to choose the LSP routine of my preference.
Any example you can provide me?
thanks
@BIGAL Has a really nice multi-radio button routine that looks like it would work.
  • Thanks 1
Here is multi radio buttons single row or column and a 2column version. Instructions are in the top of the code. You just need to save the multi lsp's into a support path or use full path when doing the (load
From the code
 (if (not AH:Butts)(load "Multi Radio buttons.lsp"))
 (if (= but nil)(setq but 1))
 (setq ans (atoi(ah:butts but "V" '("Choose a number" "1" "2" "3" "4" "5" "6" "7" "8" "9" "10")))) ; ans holds the button picked as an integer value
I wont go into it now but you can convert the dcl code made into lsp code. So don't need the multi radio.lsp. Ps Multi Toggles & Multi getvals also available.
Edited by BIGAL
  • Thanks 1
