GmoCAD Posted April 22, 2009 Posted April 22, 2009 I need to draw a text label with two lines with arrow heads, what is the bestway to do this, I tried the multileader but I could only do one line. Also I need to do a simple line with an arrowhead at the end. Any suggestions will be appreciated. Thanks Quote
lpseifert Posted April 22, 2009 Posted April 22, 2009 Do your Multileader. Then select it, rt-clk to bring up a shortcut menu, Add Leader. Quote
rkent Posted April 22, 2009 Posted April 22, 2009 you can also left click on the leader, pick the grip at the arrow while holding down the CTRL key, now copy away. Quote
Organic Posted April 26, 2009 Posted April 26, 2009 Can you draw a two headed arrow? I.e. a line (or pl) with an arrowhead on each end of it? Quote
GmoCAD Posted April 29, 2009 Author Posted April 29, 2009 Can you draw a two headed arrow? I.e. a line (or pl) with an arrowhead on each end of it? That is a good question, I am sure it can be done, I just don't know how other than using the linear dimension command with no text attached to it. On the previous arrowhead topics, I found that the qleader does the trick for a line with an arrow on one ends, you can even choose from different shapes or objects with qleader. Thank for the info Quote
