Strydaris Posted June 12, 2025 Posted June 12, 2025 Hey everyone, Was hoping someone could help me out here. I am trying to write a LISP that will update some old text styles to our newer standards. The old style were just setup with 1 style and multiple size difference. I am trying to use ssget to create a selection set to select all text or mtext with a range Lets say from 4.25 to 4.75 I think I know how to do this, but I cant seem to figure out the formatting. (ssget "_X" '((0 . *TEXT) (-4 . ">=") (40 . "4.25") (-4 . "<=") (40 . "4.25"))) I thought this was correct, but its throwing me an error. Can anyone help out with this? I want to get all text 4.25 or higher up to and equal to 4.75. Thanks Quote
Tharwat Posted June 12, 2025 Posted June 12, 2025 I guess the text height value has to be real or integer and not string. 1 Quote
Saxlle Posted June 12, 2025 Posted June 12, 2025 2 hours ago, Strydaris said: (ssget "_X" '((0 . *TEXT) (-4 . ">=") (40 . "4.25") (-4 . "<=") (40 . "4.25"))) I think you forgor to put " " in '((0 . "*TEXT") ... and also insted of (40 . "4.25") at the end need to be (40 . "4.75"). Quote
Strydaris Posted June 12, 2025 Author Posted June 12, 2025 7 minutes ago, Saxlle said: I think you forgor to put " " in '((0 . "*TEXT") ... and also insted of (40 . "4.25") at the end need to be (40 . "4.75"). HI. Yes minor spelling errors as I typed it in quickly. Mostly I wasn't sure how to use the (-4. "<=") part of the code to get the results I wanted. Thanks for the (cons - 4 "<=") version. Wasn't sure you could do that. This will allow me to use variables. Cheers. Quote
Saxlle Posted June 13, 2025 Posted June 13, 2025 10 hours ago, Strydaris said: This will allow me to use variables. Yes, on this way you can use a variables in "ssget". for e.g. (setq txth1 4.25 txth2 4.75 ss (ssget "_X" (list (cons 0 "*TEXT") (cons -4 ">=") (cons 40 txth1) (cons -4 "<=") (cons 40 txth2))) ) Quote
Lee Mac Posted June 13, 2025 Posted June 13, 2025 You can use both evaluated expressions and quoted literals in a list, e.g.: (setq ht1 4.25 ht2 4.75 sel (ssget "_X" (list '(0 . "*TEXT") '(-4 . ">=") (cons 40 ht1) '(-4 . "<=") (cons 40 ht2))) ) You might find the following tutorials useful in this regard - https://lee-mac.com/quote.html https://lee-mac.com/ssget.html 1 Quote
Strydaris Posted June 13, 2025 Author Posted June 13, 2025 @Saxlle & @Lee Mac Thanks. I got it working and I think I understand more about how to use the operators. Lee, your ssget tutorials was the first place I went when I was trying to figure this out. I did not know about your quote tutorial though. I will check it out. Thanks again all. Quote
