Mountain_XD Posted July 18 Posted July 18 Please help me Extend Lines to Polyline. Thanks so much ! Extend Lines to Polyline.dwg Quote
ScottMC Posted July 18 Posted July 18 (edited) check your 'projmode if 'extend too' entity is on a different 'Z' I like [2] Edited July 18 by ScottMC Quote
Mountain_XD Posted July 18 Author Posted July 18 1 hour ago, mhupp said: You don't need a lisp for that. just the extend command. I agree with you but what if there are a lot of polylines and lines? Quote
ScottMC Posted July 18 Posted July 18 Consider this link with multiple solutions https://www.theswamp.org/index.php?topic=53993.0 Quote
BIGAL Posted July 18 Posted July 18 Interesting Bricscad using "Fence" option. No code needed. 2 Quote
mhupp Posted July 19 Posted July 19 19 hours ago, Mountain_XD said: I agree with you but what if there are a lot of polylines and lines? Going to have to click a little then. or use fence like BIGAL shows. 1 1 Quote
ScottMC Posted July 20 Posted July 20 BIGAL that helps for sure! All the more inspires me to dig deeper into your posts/tips period. Quote
SLW210 Posted July 21 Posted July 21 On 7/18/2025 at 7:31 PM, BIGAL said: Interesting Bricscad using "Fence" option. No code needed. AutoCAD refuses to double extend for some reason. Quote
SLW210 Posted July 22 Posted July 22 For future reference, in the supplied .dwg, it's LWPolyline shapes not 2D Polyline shapes as in the title, there is a difference. LWPOLYLINE Layer: "A_Dai_Coc_S_02" Space: Model space Color: BYLAYER Linetype: "Continuous" Handle = 167 Closed Constant width 0'-0" area 5418979.86 square in. (37631.8046 square ft.) perimeter 791'-11 9/32" at point X=22622'-6 5/16" Y=176'-5 5/8" Z= 0'-0" at point X=22784'-3 15/32" Y=141'-6 27/32" Z= 0'-0" at point X=22907'-5 13/32" Y=279'-3 15/16" Z= 0'-0" at point X=22708'-11 1/16" Y=378'-6 5/32" Z= 0'-0" 2D Polyline POLYLINE Layer: "KCS_DIM" Space: Model space Color: BYLAYER Linetype: "Continuous" Handle = 179 Open starting width 0'-0" ending width 0'-0" area 0.00 sq in (0.0000 sq ft) length 2566'-5 17/32" VERTEX Layer: "KCS_DIM" Space: Model space Color: BYLAYER Linetype: "Continuous" Handle = 17b at point, X=23794'-4 1/8" Y=-362'-5 9/32" Z= 0'-0" starting width 0'-0" ending width 0'-0" VERTEX Layer: "KCS_DIM" Space: Model space Color: BYLAYER Linetype: "Continuous" Handle = 17c at point, X=21227'-10 19/32" Y=-362'-5 9/32" Z= 0'-0" starting width 0'-0" ending width 0'-0" END SEQUENCE Layer: "KCS_DIM" Space: Model space Color: BYLAYER Linetype: "Continuous" Handle = 17a If I have time, I'll see what I can come up with. Quote
SLW210 Posted July 22 Posted July 22 On 7/18/2025 at 8:04 PM, mhupp said: Going to have to click a little then. or use fence like BIGAL shows. Even with AutoCAD probably still pretty fast for fence, but a LISP would help. I tried several things and I can't get AutoCAD 2026 to double extend as per @BIGAL's example. 1 Quote
mhupp Posted July 22 Posted July 22 9 hours ago, SLW210 said: I tried several things and I can't get AutoCAD 2026 to double extend as per @BIGAL's example. I know he uses BricsCAD and I used it for the last 5 years when I was still working in CAD. liked it a lot more the AutoCAD. there are differences but mostly for the better like double extend. 1 Quote
SLW210 Posted July 23 Posted July 23 I just did a quick look in AutoCAD, this may be a bit tricky for me. Let me get my paid to do work done and I'll do more looking. Quote
Tsuky Posted July 23 Posted July 23 On 7/22/2025 at 12:55 PM, SLW210 said: I tried several things and I can't get AutoCAD 2026 to double extend as per @BIGAL's example. It works, but the fence must pass on each side of the middle of the segment to be extended. Quote
SLW210 Posted July 23 Posted July 23 6 hours ago, Tsuky said: It works, but the fence must pass on each side of the middle of the segment to be extended. I tried that everyway possible and no luck with AutoCAD 2026, if I get time I'll look through my settings again. Might be a quirk in my AutoCAD 2026. It does seem it used to work as you say. Quote
BIGAL Posted July 24 Posted July 24 Here is the help for Extend it has some variables you can set may be applicable for Acad. https://help.bricsys.com/en-us/document/command-reference/e/extend-command?version=V25&id=165079077042 1 Quote
SLW210 Posted July 24 Posted July 24 I got it now, very fast double extend now. Current settings: Projection=UCS, Edge=None, Mode=Standard then Fence option. If I recall you used to be able to double extend with crossing as well. If I get time I'll dig a little deeper. You have to be careful any extra crossings will send the extend through the closed shapes. 1 Quote
