Mountain_XD Posted July 18 Posted July 18 Please help me Extend Lines to Polyline. Thanks so much ! Extend Lines to Polyline.dwg Quote
ScottMC Posted July 18 Posted July 18 (edited) check your 'projmode if 'extend too' entity is on a different 'Z' I like [2] Edited July 18 by ScottMC Quote
Mountain_XD Posted July 18 Author Posted July 18 1 hour ago, mhupp said: You don't need a lisp for that. just the extend command. I agree with you but what if there are a lot of polylines and lines? Quote
ScottMC Posted July 18 Posted July 18 Consider this link with multiple solutions https://www.theswamp.org/index.php?topic=53993.0 Quote
BIGAL Posted July 18 Posted July 18 Interesting Bricscad using "Fence" option. No code needed. 2 Quote
mhupp Posted July 19 Posted July 19 19 hours ago, Mountain_XD said: I agree with you but what if there are a lot of polylines and lines? Going to have to click a little then. or use fence like BIGAL shows. 1 1 Quote
ScottMC Posted Sunday at 12:51 AM Posted Sunday at 12:51 AM BIGAL that helps for sure! All the more inspires me to dig deeper into your posts/tips period. Quote
SLW210 Posted Monday at 10:31 AM Posted Monday at 10:31 AM On 7/18/2025 at 7:31 PM, BIGAL said: Interesting Bricscad using "Fence" option. No code needed. AutoCAD refuses to double extend for some reason. Quote
SLW210 Posted Tuesday at 10:52 AM Posted Tuesday at 10:52 AM For future reference, in the supplied .dwg, it's LWPolyline shapes not 2D Polyline shapes as in the title, there is a difference. LWPOLYLINE Layer: "A_Dai_Coc_S_02" Space: Model space Color: BYLAYER Linetype: "Continuous" Handle = 167 Closed Constant width 0'-0" area 5418979.86 square in. (37631.8046 square ft.) perimeter 791'-11 9/32" at point X=22622'-6 5/16" Y=176'-5 5/8" Z= 0'-0" at point X=22784'-3 15/32" Y=141'-6 27/32" Z= 0'-0" at point X=22907'-5 13/32" Y=279'-3 15/16" Z= 0'-0" at point X=22708'-11 1/16" Y=378'-6 5/32" Z= 0'-0" 2D Polyline POLYLINE Layer: "KCS_DIM" Space: Model space Color: BYLAYER Linetype: "Continuous" Handle = 179 Open starting width 0'-0" ending width 0'-0" area 0.00 sq in (0.0000 sq ft) length 2566'-5 17/32" VERTEX Layer: "KCS_DIM" Space: Model space Color: BYLAYER Linetype: "Continuous" Handle = 17b at point, X=23794'-4 1/8" Y=-362'-5 9/32" Z= 0'-0" starting width 0'-0" ending width 0'-0" VERTEX Layer: "KCS_DIM" Space: Model space Color: BYLAYER Linetype: "Continuous" Handle = 17c at point, X=21227'-10 19/32" Y=-362'-5 9/32" Z= 0'-0" starting width 0'-0" ending width 0'-0" END SEQUENCE Layer: "KCS_DIM" Space: Model space Color: BYLAYER Linetype: "Continuous" Handle = 17a If I have time, I'll see what I can come up with. Quote
SLW210 Posted Tuesday at 10:55 AM Posted Tuesday at 10:55 AM On 7/18/2025 at 8:04 PM, mhupp said: Going to have to click a little then. or use fence like BIGAL shows. Even with AutoCAD probably still pretty fast for fence, but a LISP would help. I tried several things and I can't get AutoCAD 2026 to double extend as per @BIGAL's example. 1 Quote
mhupp Posted Tuesday at 08:47 PM Posted Tuesday at 08:47 PM 9 hours ago, SLW210 said: I tried several things and I can't get AutoCAD 2026 to double extend as per @BIGAL's example. I know he uses BricsCAD and I used it for the last 5 years when I was still working in CAD. liked it a lot more the AutoCAD. there are differences but mostly for the better like double extend. 1 Quote
SLW210 Posted Wednesday at 12:16 PM Posted Wednesday at 12:16 PM I just did a quick look in AutoCAD, this may be a bit tricky for me. Let me get my paid to do work done and I'll do more looking. Quote
Tsuky Posted Wednesday at 12:29 PM Posted Wednesday at 12:29 PM On 7/22/2025 at 12:55 PM, SLW210 said: I tried several things and I can't get AutoCAD 2026 to double extend as per @BIGAL's example. It works, but the fence must pass on each side of the middle of the segment to be extended. Quote
SLW210 Posted Wednesday at 07:00 PM Posted Wednesday at 07:00 PM 6 hours ago, Tsuky said: It works, but the fence must pass on each side of the middle of the segment to be extended. I tried that everyway possible and no luck with AutoCAD 2026, if I get time I'll look through my settings again. Might be a quirk in my AutoCAD 2026. It does seem it used to work as you say. Quote
BIGAL Posted yesterday at 12:10 AM Posted yesterday at 12:10 AM Here is the help for Extend it has some variables you can set may be applicable for Acad. https://help.bricsys.com/en-us/document/command-reference/e/extend-command?version=V25&id=165079077042 1 Quote
SLW210 Posted 14 hours ago Posted 14 hours ago I got it now, very fast double extend now. Current settings: Projection=UCS, Edge=None, Mode=Standard then Fence option. If I recall you used to be able to double extend with crossing as well. If I get time I'll dig a little deeper. You have to be careful any extra crossings will send the extend through the closed shapes. Quote
