hi,
can someone please assist me on creating a lisp:
create polyline then after closing, it will automatically create a solid hatch within the closed polyline. hatch should be solid and layer is as per current. command should be PLH
big thanks. we are working on large scale landscape projects that need hatches of each area of soft scape and hardscape
Without using Visual LISP reactors, here's a starting point:
(defun c:PLH (/ pt)
  (command "._pline")
  (while
    (and
      (not (initget 32))
      (if pt
        (setq pt (getpoint pt))
        (setq pt (getpoint))
     (command pt)
  (command "_c")
  (command "._-hatch"
           "_p"
           "_s"
           "_co"
           "_la"
           "_s"
           (ssadd (entlast))
Edited by BlackBox
@BlackBox Beat me to the Punch! 😁
@james9710 Here is my version - as simple as I can make it:
(defun C:PLH (/ e el)
   (command "._pline")
   (while (= (logand (getvar "cmdactive") 1) 1)
		(command pause)
   (if
      (and
         (setq e  (entlast))
         (setq el (entget e))
         (= (cdr (assoc 0 el)) "LWPOLYLINE")
         (= (logand (cdr (assoc 70 el)) 1) 1)
      (command "._-hatch" "_pro" "_S" "_S" e "" "")
      (princ "\nInvalid Polyline Created (Must be complete and Closed).")
Edited by pkenewell
  • Like 2
   (command "._pline")
		(command pause)
   (if
      (and
         (setq e  (entlast))
'... as simple'... using logand. (chortles) Teeheehee
Props though, as yours allows arcs, etc... Well done :beer:
Edited by BlackBox
@BlackBox Thanks! 😆 (yeah - logand is fairly advanced, but shorter lol)
Hi All,
managed to tweak this code slightly so it draws into a specific layer and then removes the polyline at the end so you are just left with solid hatch. just wondering if i wanted to specify a certain hatch pattern instead of solid (eg ANSI34 with scale of 10 and angle of 90) how would i do that?
(defun C:PLH (/ e el old_layer hatch_ent)
   ;; Store the current layer
   (setq old_layer (getvar "clayer"))
   ;; Set the desired layer for the polyline and hatch
   (command "._layer" "_m" "layernamehere" "") ; Create layer if it doesn't exist
   (command "._layer" "_s" "layernamehere" "") ; Set current layer
   (command "._pline")
        (command pause)
   (if
      (and
         (setq e  (entlast)) ; 'e' now holds the entity name of the polyline
         (setq hatch_ent (entlast)) ; Get the entity name of the newly created hatch
         (entdel e) ; Delete the polyline using its entity name 'e'
   ;; Restore the original layer
   (command "._layer" "_s" old_layer "")
How are you creating the polyline?
You can use -Hatch with the "draW boundary" option, just a few clicks for a solid hatch on current layer.
  • Like 2
10 hours ago, masterfal said:
Hi All,
   (command "._pline")
        (command pause)
   (if
      (and
@masterfal Simple - just replace the the options in the command statement for the -HATCH command
; Replace Hatch command line (command "._-hatch" "_pro" "_S" "_S" e "" "") with:
(command "._-hatch" "_Pro" "ANSI34" "10.0" "90" "_S" e "" ""); where after "Pro" (properties), the arguments are [Pat. Name] [Scale] [Rotation]
Edited by pkenewell
@SLW210
That's true! the command could be boiled down to this below if you don't want a polyline boundary. However, the PLINE command has more options, and there are 2 extra returns that you have to press at the end to complete the command - that's why I would stick to the original.
   (command "._-hatch" "_Pro" "ANSI34" "10.0" "90" "_W" "_N")
		(command pause)
Edited by pkenewell
how am i creating polyline? what do you mean..? i just click the points where i want my polyline and c to close. isn't that how everyone does it?
i need the hatch in specific hatch layer which would rarely be my current layer + the correct hatch pattern wont always be the last used so i thought setting a little routine that specifies layer and hatch pattern would be the quickest way. this way i just type plh, enter, click click click with mouse, c to close and thats it. surely thats gotta be quicker than running original -hatch and manually entering required hatch/layer types?
Edited by masterfal
Ahh i see.. i knew was going to be something like that, just couldnt work out exactly what to change.
Works like a charm. Appreciate the help! one thing i just noticed though is its not actually drawing the hatch in the correct layer. its drawing the polyline in the correct layer (which gets removed at the end) but the layer the hatch is being put in is whatever layer is set in the hatch dialog box when you run the hatch command. basically just using the previous layer that was used when doing hatch. how can i fix so it drops the hatch into my specified layer?
I wasn't talking to you.
I was asking the OP, if not mentioned by name or quoted it is presumed all over the internet the question is for the OP.
But, I mentioned, no LISP needed if you are manually making a polyline, -Hatch with "draW boundary" option.
I see no need for a LISP and you can also leave a polyline if needed.
@masterfal
First Check the HPLAYER and other HP... variables. These will make a hatch on a particular layer and other specifications regardless of what layer is set current. You have to set HPLAYER to blank (type in a "." for the setting). Look up HPLAYER in your help and it will explain. You can also set HPLAYER to the layer you want in code using (setvar "HPLAYER" "MyLayer")
Edited by pkenewell
So I saw this post and came up with the idea to create a lisp to draw polyline once closed it will insert the area of the polyline at the centre (this is for drainage catchment). Did I overcomplicate the lisp? Initially I was going for static text, but I am all about making life easier so tried to merge the ATC function from the lisp here https://jtbworld.com/autocad-areatext-lsp  .
Any feedback on the below lisp would be appreciated.
Thank you all!
(setq jtbfieldformula ">%).Area \\f \"%lu2%pr1%ps[,m²]%ct8[0.001]\">%")
(defun Get-ObjectIDx64 (obj / util)
  (setq util (vla-get-Utility
               (vla-get-activedocument (vlax-get-acad-object))
  (if (= (type obj) 'ENAME)
    (setq obj (vlax-ename->vla-object obj))
  (if (= (type obj) 'VLA-OBJECT)
    (if (> (vl-string-search "x64" (getvar "platform")) 0)
      (vlax-invoke-method
        util
        "GetObjectIdString"
        obj
        :vlax-False
      (rtos (vla-get-objectid obj) 2 0)
(defun c:CTS-DrawGullyCatchment ()
  (if (not (tblsearch "LAYER" "CTS-Gully Catchment"))
    (command "-LAYER"
             "_M"
             "CTS-Gully Catchment" ;;Set Layer Name
             "_C"
             "True"
             "0,255,0" ;;Set Color
(command "._pline")
  (while
    (and
      (not (initget 32))
      (if pt
     (command pt)
  (command "_c")
  (if
      (and
        (command "._area" "_o" e)
        ;;(setq GullyArea (getvar "area")) ; Get the area of the polyline
        ;;(setq GullyAreaTxt (strcat (rtos GullyArea 2 2) "m2"))
        ;;(setq GullyAreaTxtPt (getpoint "\nSpecify point for Guylly Cathcment text:"))
        (vl-load-com)
        (setq entObject       (vlax-ename->vla-object (setq ent (entlast))))
        (setq entObjectID     (Get-ObjectIDx64 entObject))
        (setq lastpt          (getvar "lastpoint"))
        (setq InsertionPoint  (vlax-3D-Point(trans (osnap lastpt "_gcen") 1 0)))
        (setq ad              (vla-get-ActiveDocument (vlax-get-acad-object)))
        (setq mtextobj
         (vla-addMText
           (if (= 1 (vla-get-activespace ad))
             (vla-get-modelspace ad)
             (if (= (vla-get-mspace ad) :vlax-true)
               (vla-get-paperspace ad)
           InsertionPoint
           0.0
           (strcat
             "%<\\AcObjProp Object(%<\\_ObjId "
             entObjectID
             jtbfieldformula
        (vla-put-AttachmentPoint mtextobj 5)
        (vla-put-insertionPoint mtextobj InsertionPoint)
Edited by CivilTechSource
