UnFormat.lsp does not work in Autocad 2021
I'll put this one here for later.
I have a suspicion that the text is still there, just not visible - very small perhaps. This will show all the mtext values (first 256 characters anyway) in the drawing. Run it after your unformat just to confirm that the texts have been deleted or are just not visible.
(defun c:GrabTexts ( / MySS acount MyEnt)
  (setq myss (ssget "_X" '((0 . "mtext"))))
  (setq acount 0)
  (while (< acount (sslength myss))
    (setq Myent (ssname Myss acount))
    (princ "\n")(princ (assoc 1 (entget MyEnt)))
    (setq acount (+ acount 1))
  ) ; end while
  • Thanks 1
29 minutes ago, GLAVCVS said:
Write before (vla-put-textstring obj (vla-get-TextString obj)) this: (print (vla-get-TextString obj)), загрузите, запустите и опубликуйте скриншот того, что произошло в командной строке
PS: Also make sure you've closed all the parentheses in your Lisp expression: your last message seems to be missing a closing parenthesis.
((= otyp "MTEXT")(print (vla-get-TextString obj))(vla-put-TextString obj (supriFMT (vla-get-TextString obj)))) ; AcDbMText
It looks like it worked! Thank you all!
I'll test it again.
I'll test it again.
But I still haven't figured out what the problem is...
Maybe you deleted some parentheses when you removed the T argument.
No, I didn't understand why the first code didn't work.
Edited by Nikon
  (setq acount 0)
  ) ; end while
GRABTEXTS
Writing on the command line:
(1 . )
(1 . )
It's simply that your version of LM:UnFormat (I don't know if it's the original or modified one) isn't compatible with some localized versions of AutoCAD.
Is your version of AutoCAD 2019 on the same PC as the 2021 version?
  • Thanks 1
Yes, both versions are on the same computer. And before that, everything worked in autocad 2015. That's why I'm at a loss. Thank you very much.
