ILoveMadoka Posted August 28, 2025 Posted August 28, 2025 I want to create a dynamic block with 4 visual states. I want two text values to appear in each state but in different places in each state. If I understand correctly you cannot move an attribute from state to state. Fields would work but I have no way of knowing how many of these blocks may be needed in a particular drawing. If I copy the attributes from VS to VS when creating the block, they only are available in the first state. The other states report there is no editable attributes but if I edit the state they are there. Here is a diagram of the 4 visual states. (the red is not part of the block, just a separator) I had created a block with 8 attributes but users found it confusing or difficult to navigate. Is there a way to achieve this in a simpler/better fashion? Quote
BIGAL Posted August 28, 2025 Posted August 28, 2025 This is very similar to the problem of draw a section marker, if your happy with a lisp answer can be done very easy, you have 4 choices or can be based on say 3 point pick. Would use say 2 blocks. a HOR and VER arrow. The other way may be to look at the angle the block is inserted and rotate the attribute about a centre justification, not sure if can do that in a dynamic block. will have a play. Some one else may jump in with a new dynamic block. Did something similar in another post that stretches the gap between the arrows. Quote
ILoveMadoka Posted August 29, 2025 Author Posted August 29, 2025 This is indeed a Section Marker. Lisp is always welcome but I don't know where to start. Maybe the 8 attribute solution is the closest I can get... The Text Alignment is different in each of the views. Creating a field as part of the Insert would work but It would have to take into consideration how many similar fields were existing in the drawing then increment the value/name then reassign the new field to the new block. Beyond my novice skill set.. Quote
CyberAngel Posted August 29, 2025 Posted August 29, 2025 Have a look at the video linked on this page. I can't quite follow it, but could you create an invisible attribute and echo it to the four positions? Quote
ILoveMadoka Posted August 29, 2025 Author Posted August 29, 2025 I'm looking... Hard to follow indeed... hate videos with no audio... <thx!> Quote
ILoveMadoka Posted August 29, 2025 Author Posted August 29, 2025 (edited) I have an idea but am about to leave for the long weekend.. Have an editable attribute for the Letter and the Number and when you enter that data, it sets another value for each of the 4 states. They can have a separate "non editable" attributes. Each state would have two attributes but they are all set by editing a single attribute in the main block. Edit the data once, set 8 attribute values from that. Can't explain it very well. Once I figure out the logistics, I'll ask for some help in the lisp section.. Edited August 29, 2025 by ILoveMadoka Quote
