Anyone have any hints on how to get Spline Leader lengths?
Ultimately, I am looking to make several already drawn spline leaders the same length.
As a spline gives two answers the points answer and another with nodes. So any way if you explode the Mleader then you can get at the spline using this. Just need to check that the spline is last entity, tested in Bricscad. A disclaimer not sure if length is correct. I think it is short by length of arrow. Will try to find arrow length. Yep found it.
(defun c:wow ( / plent pt len lenar)
  (setq plent (entsel "\nPick mleader "))
  (setq lenar (cdr (assoc 140 (entget (car plent)))))
  (command "undo" "M")
  (command "explode" (car plent))
  (setq ent (ssname (ssget "L") 0))
  (setq len (getpropertyvalue ent "length"))
  (command "undo" "B")
  (alert (strcat "Total  length is " (rtos (+ lenar len) 2 3)))
(c:wow)
I think you could do a "I want a length of 100 by drawing something close then move say arrow point till you get approx 100. Via lisp. It would be a two step process explode and move then undo and reset arrow head point.
  • Thanks 1
17 hours ago, 1958 said:
It would be nice if you could put the prompts and comments in English.
I saw the Dogleglength when I did a dump on a Mleader. I'll see what I come up with.
(c:wow)
I know how to get a Spline length, I don't want to explode the Mleaders, defeats the purpose.
The Undo un-explodes them though.  On my phone. Will have a look at the lsp tomorrow.
Edited by BIGAL
But wouldn't undo change it back to original length?
Quote
On 8/28/2025 at 12:45 PM, 1958 said:
Still looking to decipher this one, probably tomorrow when I get back to work.
As I suggested can move the vertices and return the new length or say draw something and move say the first point keep repeating till it is the length you want.
Will have a play.
@SLW210
Quote
You are rigth this is the good direction for your ask. Try this
(defun c:length2lead ( / AcDoc Space ss dog_l n sel obj)
  (setq
    AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
    Space
    (if (= 1 (getvar "CVPORT"))
      (vla-get-PaperSpace AcDoc)
      (vla-get-ModelSpace AcDoc)
  (vla-startundomark AcDoc)
  (princ "\nSelect mleader")
  (while
    (not
      (setq ss
        (ssget
          (list
            '(0 . "MULTILEADER")
            (cons 67 (if (eq (getvar "CVPORT") 1) 1 0))
            (cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model"))
  (initget 7)
  (setq dog_l (getdist (getvar "VIEWCTR") "nNew length for multileader?: "))
  (repeat (setq n (sslength ss))
    (setq
      sel (ssname ss (setq n (1- n)))
      obj (vlax-ename->vla-object sel)
    (vla-put-DoglegLength obj dog_l)
    (vla-regen AcDoc acactiveviewport)
  (vla-endundomark AcDoc)
  (prin1)
  • Thanks 1
I don't think dogleglength is what you want. This example is original mleader was 33 tried dogleglength at 35 can see is way to long. Like twice the length required. it was like 70+
The only way I have found is to move either the 1st or last point and can get the desired spline length, but a big but must explode and recalc the spline point and then undo and reset the mleader then its length is correct. Or within say 1e-03 etc. I have not found a way to get a length of a mleader spline. Some one else may know. The default dogleg length is in the Mleaderstyle, I have started to play with it set to 0.0 asked me it makes it easier to work out lengths.
Starting to look at making a spline so can easy recalc without any explodes.
This shows in red what I consider the spline length. Note have to add arrow size. Please confirm. Can you also post a dwg with sample mleaders.
Edited by BIGAL
I thought I posted this yesterday.
Yes, DOGLEGLENGTH is the landing, they should all be 0, but to make sure, it needs accounted for.
May need to dig into something deeper.
It's not a super important deal at the moment, I was just curious as to why it's so obscure for methods to manipulate Multileaders/Leaders without exploding.
I have no Mtext, just have some routes, and would like them to match lengths, I need the arrow to relocate, not the landing.
I have posted a test drawing.
For future work, drawing them to a specific length would be nice, that seems to be what 1958's LISP does, still trying to decipher it though.
P.S.
After some testing, ml.lsp asks to select a line and then draws an Mleader and places text for the length, best I can decipher.
MLeader Test.dwg
I think the translation to 1958's lisp is this, although not quite sure is the best
;;; Multi-length
;;; https://www.cadtutor.net/forum/profile/26931-1958/
;;; 28 august 2025
(defun c:ml (/ ent pline txt p1 p2)
 (vl-load-com)
 (while (setq pline (vlax-ename->vla-object (car (setq ent (entsel "\n indicate the line \n")))))
  (setq txt (strcat "L = " (rtos (vlax-curve-getDistAtParam pline (vlax-curve-getEndParam pline)) 2 2) " m" )
  (setq p1 (vlax-curve-getClosestPointTo pline (cadr ent))
        p2 (getpoint p1 "\n insertion point >> \n")
  (vl-cmdf "_mleader" p1 p2 txt)
  (setq ent (vlax-ename->vla-object (entlast)))
  (vla-put-TextHeight ent 2.00) 			; font size (height)
  (vla-put-TextJustify ent 1) 				; text alignment (1-left)
  (vla-put-TextLeftAttachmentType ent 4)	 	; append text to left
  (vla-put-TextRightAttachmentType ent 4) 		; append text to the right
;;; 0 - top of line 1
;;; 1 - middle of line 1
;;; 2 - bottom of line 1
;;; 3 - underline of line 1
;;; 4 - middle of text
;;; 5 - middle of last line
;;; 6 - bottom of last line
;;; 7 - underline of last line
;;; 8 - underline of all text
  (vla-put-DoglegLength ent 0.5) 			; shelf size (length)
;;; (vla-put-TextStyleName ent "ext til")		; change text style
 ;|?Visual LISP  Format Options?
(100 1 2 2 nil " " 80 60 0 0 0 nil nil nil T)
;*** Please add text under the comments! ***|;
  • Thanks 1
I have some test code and it adjusts a spline can move start or end as a choice.
In the ML it uses 2 points so there is no drama in making a Mleader with a correct length as its just a case of moving arrow along the angle of the leader line. So just reset p2 to be correct length.
This will draw a 2pt leader.
(defun c:wow1 ( / )
(setq p1 (getpoint "\nPick 1st point ")
        p2 (getpoint p1 "\n insertion point >> ")
(setq ang (angle p1 p2))
(setq d1 (rtos (distance p1 p2) 2 3))
(setq str (strcat "\n  existing is " d1 " Enter new length "))
(setq d2 (getreal str))
(setq p2 (polar p1 ang d2))
(command "Mleader" p1 p2 (getstring "\nEnter text "))
(vla-put-DoglegLength ent 0.0)
(c:wow1)
 Note the mleader style must be set to 2 points. For the spline type answer I used 4 points max in the mleader style, I thought that was what you wanted. A 3 -4 curved leader of a known length.
  • Thanks 1
I have more than 2 points most of the time.
I'm wanting to fix already drawn leaders by matching the size and draw leaders to a specific length.
Yes, I did some looking yesterday and  from what I could find AutoCAD doesn't have the information exposed to API to get an exact length with more than 2 points.
So I have this working so far, not super accurate on multipoint Spline Multileaders, but close enough, seems accurate on some tested 2 point Multileaders.
Changing the multipoint Multileaders to Straight Multileaders then running the LISP, then converting back to Spline Multileaders seems more accurate.
Only quickly tested, so I'll know more later today if any problems arise.
If interested it can be tested on the drawing I posted earlier.
;;; Match selected Multileader lengths using first selection.
;;; https://www.cadtutor.net/forum/topic/98672-get-length-of-mleaderqleader-spline/#findComment-676006
;;; By SLW210 (a.k.a. Steve Wilson)
(defun c:MLMtchLgnth (/	  sel	     firstLeader
		       vlaFirst	  firstLength		i
		       ent	  vlaCurrent pts	allPts
		       curLanding curLength  scaleFactor
		       newPts	  sa	     prevPt	pt
  (vl-load-com)
  ;; Select MLeaders
  (setq sel (ssget '((0 . "MULTILEADER"))))
  (if sel
      ;; First selected leader
      (setq firstLeader (ssname sel 0))
      (setq vlaFirst (vlax-ename->vla-object firstLeader))
      ;; Get points from First leader
      (setq pts	(vlax-safearray->list
		  (vlax-variant-value
		    (vla-GetLeaderLineVertices vlaFirst 0)
      (setq allPts (vl-list->3dpoints pts))
      ;; Measure first leader length
      (setq firstLength 0.0)
      (setq prevPt (car allPts))
      (foreach pt (cdr allPts)
	(setq firstLength (+ firstLength (distance prevPt pt)))
	(setq prevPt pt)
      (princ (strcat "\nFirst leader length: "
		     (rtos firstLength 2 2)
      ;; Process leaders
      (setq i 1)
      (while (< i (sslength sel))
	(setq ent (ssname sel i))
	(setq i (1+ i))
	(setq vlaCurrent (vlax-ename->vla-object ent))
	;; Get vertices
		    (vlax-variant-value
		      (vla-GetLeaderLineVertices vlaCurrent 0)
	;; Skip if less than 2 points
	(if (> (length allPts) 1)
	    (setq curLanding (last allPts))
	    ;; Measure current length
	    (setq curLength 0.0)
	    (setq prevPt curLanding)
	    (foreach pt	(reverse allPts)
	      (setq curLength (+ curLength (distance prevPt pt)))
	      (setq prevPt pt)
	    ;; Compute scale factor
	    (setq scaleFactor (/ firstLength curLength))
	    ;; Build new points
	    (setq newPts '())
	    (foreach pt	allPts
	      (setq newPts (append newPts
				   (list (scale-point pt curLanding))
	    ;; Flatten to doubles
	    (setq pts (apply 'append newPts))
	    ;; Create and fill SafeArray
	    (setq sa (vlax-make-safearray
		       vlax-vbDouble
		       (cons 0 (- (length pts) 1))
	    (vlax-safearray-fill sa pts)
	    ;; Apply modified points
	    (vla-SetLeaderLineVertices
	      vlaCurrent
	      0
	      (vlax-make-variant sa)
	    (princ (strcat "\nAdjusted leader to length "
	  (princ "\nSkipping leader with insufficient vertices.")
    (princ "\nNo MLeaders selected.")
;; Flat list to 3D points
(defun vl-list->3dpoints (lst / out)
  (setq out nil)
  (while (>= (length lst) 3)
    (setq out (cons (list (car lst) (cadr lst) (caddr lst)) out))
    (setq lst (cdddr lst))
  (reverse out)
;; Scale vector from landing
(defun scale-delta (landing pt)
  (list
    (* scaleFactor (- (nth 0 pt) (nth 0 landing)))
    (* scaleFactor (- (nth 1 pt) (nth 1 landing)))
    (* scaleFactor (- (nth 2 pt) (nth 2 landing)))
;; Scale point
(defun scale-point (pt landing)
  (if (and (listp pt) (= (length pt) 3))
    (mapcar '+ landing (scale-delta landing pt))
    pt
I wasted too much time on this, so drawing Multileaders to exact lengths will have to wait.
I had most of it deciphered, but thanks that's much better than I ended up with.
I may yet have use for it.
Just a comment, If you compare the length of using vertices against the length of the spline they are different. So that was why I was exploding the mleader and playing with adjusting say the arrow point. The code I posted for 2 point mleaders could be easily changed to work with 3 or 4 vertices, ie a straight segment Mleader. That is why I was looking at making a matching spline and adjust it till correct length with doglegend = 0.0. Just have to work out how to set tangential line start to spline.
A when have time task.
Yes, it could use some more refinement, but plenty close for what I need right now, I would like to get this LISP working on Leaders as well.
I did get some headway on drawing a multileader to length, but spent too much time on this already, I have a couple of quick projects at work to knock out, so probably get back to it next week.
I also looked at exploding, didn't really seem to be much better. When time allows I will play some more.
This is way closer works for 2, 3 & 4 points may be able to add more. version 2 will add the Multi getvals dcl for arrow, text height and length. just proof of concept, its length is still off by a little bit may add a fuzz factor to get closer.
;m Draw a spline mleader mwith a length
; By AlanH Setp 2025
; Not quite true length but close.
(defun c:spl ( / ang arrowlen co-ord ent len len2 newlen num obj pt pt1 pt2 pt3 str txtht x)
(defun AddMLeader (ptslst numpts newstr arrow tht / doc points i )
  (setq points (vlax-make-safearray vlax-vbDouble (cons 0  numpts)))
  (vlax-safearray-fill points ptslst)
  (setq i 0)
(setq curspace (vlax-get-property (vla-get-ActiveDocument (vlax-get-acad-object))
(nth (vla-get-ActiveSpace (vla-get-ActiveDocument (vlax-get-acad-object)))
'(PaperSpace ModelSpace)))
  (setq mLeader (vla-AddMLeader curspace points i))
  (vlax-put mleader 'dogleglength 0.0)
  (vlax-put mleader 'leadertype 2)
  (vlax-put mleader 'textstring newstr)
  (vlax-put mleader 'Arrowheadsize arrow)
  (vlax-put mleader 'Textheight tht)
(defun plpts ( / pt)
(setq pt (getpoint "\nStarting point of Mleader Enter to stop : "))
(command "_pline" pt)
(while (= (getvar "cmdactive") 1 )
(command (getpoint (getvar 'lastpoint)))
;;;;;;;; starts here
(plpts)
(setq ent (entlast))
(setq obj (vlax-ename->vla-object ent))
(setq pt1  (vlax-curve-getstartPoint obj))
(setq ang (angle pt1 (vlax-curve-getendPoint obj)))
(setq len (vlax-get obj 'length))
(setq arrowlen 4 txtht 4.0)
(setq newlen (getreal (strcat "\nExisting length is " (rtos len 2 3) " Enter new length ")))
(setq str (getstring "\nEnter label " T))
(setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget ent))))
(cond
 ((= (length co-ord) 2)
  (setq lst '() num 5)
  (setq pt (nth  0 co-ord))
  (setq lst (cons 0  lst))
  (setq lst (cons (cadr pt) lst))
  (setq lst (cons (car pt) lst))
  (setq pt2 (polar pt (angle pt (nth 1 co-ord)) newlen))
  (setq lst (cons (cadr pt2) lst))
  (setq lst (cons (car pt2) lst))
 ((= (length co-ord) 3)
  (setq lst '() x -1 num 8)
  (repeat 2
   (setq pt (nth (setq x (1+ x)) co-ord))
  (setq pt2 (nth (- (length co-ord) 2) co-ord))
  (setq len2 (vlax-curve-getdistatpoint obj pt2))
  (setq len2 (- len len2))
  (setq pt2 (polar pt2 (angle pt2 (last co-ord)) len2))
 ((= (length co-ord) 4)
  (setq lst '() x -1 num 11)
  (repeat 3
(command "erase" ent "")
(addmleader lst num str arrowlen txtht)
(C:spl)
Seems a good start.
Here is what I get when running it...
Command: SPL
Starting point of Mleader Enter to stop : _pline
Specify start point:
Current line-width is 0'-0"
Specify next point or [Arc/Halfwidth/Length/Undo/Width]: L
Invalid point.
90
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]:
Command:
Existing length is 90.000 Enter new length 85
Enter label
erase
Select objects:   1 found
Select objects:
Command: ; error: Exception occurred
