Break an object at 2 points and replace the properties of the line
On 9/11/2025 at 8:31 AM, Nikon said:
Thank
The code works perfectly for straight sections. For circles and arcs, I would like to simply change the properties of the lines between points pt1 and pt2.
There is no need to connect these points with a straight line.
I think I read your first explanation too quickly.
I also thought about keeping the main part of your code to avoid overcomplicating my answer.
But in the end, I decided to spend a little time improving the code.
Here's another option for doing this task.
One possible difference (or not) with the other options discussed in this thread is that the cut points may or may not be on the object to be cut: when they aren't, it will calculate the perpendicular point.
Another small difference is that here, you're still required to first select the object to be modified to avoid the problem of cases where several objects coincide at the same point.
(defun c:Br2ptReplDash (/ para	  tl	  ss	  pt1	  pt2
			  p1	  p2	  ent	  vlae	  ep
			  to	  c	  r	  eumk	  entdata
			  newent  entUlt  osmant  ecoA	  lstChg
			  lstR	  lent1	  lent	  pIni	  pFin
			  dameSeg *troca* erroria errores error0
  (defun erroria ()
    (defun errores (mens)
      (setq *error* error0)
      (command-s "._undo" "_1")
      (prin1)
    (setq error0  *error*
	  *error* errores
  (defun dameSeg (e p1 p2 / vlae pIni pFin rg)
    (setq pIni (vlax-curve-getPointatParam (setq vlae (vlax-ename->vla-object e)) (vlax-curve-getStartParam vlae))
	  pFin (vlax-curve-getPointatParam vlae (vlax-curve-getEndParam vlae))
	  rg (* (getvar "PICKBOX") (/ (getvar "VIEWSIZE") (cadr (getvar "SCREENSIZE"))) 1.01)
    (if (and (or
	       (equal p1 pIni rg)
	       (equal p1 pFin rg)
	     (or
	       (equal p2 pIni rg)
	       (equal p2 pFin rg)
      T
  (defun grreadea (/ para lr )
    (while (not para)
      (princ "\rPress TAB to switch modifications, Select next object to split or RIGHT CLICK to EXIT...")
      (setq lr (grread T 4 2))
      (cond
	((= (car lr) 2)
	 (cond
	   ((= (cadr lr) 9)
	    (setq *troca* (not *troca*))
	    (entmod (append (if *troca* lent lent1) lstChg))
	    (entmod (append (if *troca* lent1 lent) lstR))
	((= (car lr) 25) (setq para 0 ep nil) )
	((= (car lr) 3)
	 (if (listp (cadr lr))
	   (setq ep (nentselp (cadr lr))
		 ep (if (wcmatch (cdr (assoc 0 (entget (car ep)))) "*LINE,ARC,CIRCLE") ep)
		 para (if ep T)
	(T (if (/= (car lr) 5) (print lr) ))
    para
  (erroria)
  (setq	osmant (getvar "OSMODE")
	ecoA (getvar "CMDECHO")
	eumk nil
	tl "DASHED2"
	tl (if (tblsearch "LTYPE" tl)
	     tl
	       (vlr-beep-reaction)
	       (alert (princ (strcat "\n*** Linetype " tl " not found. It will be instead CONTINUOUS")))
	       "CONTINUOUS"
	lstChg (list
		 '(8 . "0")	; the default layer
		 (cons 6 tl)	; line type
		 '(48 . 0.25)	; thickness
		 '(62 . 84)     ; color
  (setvar "CMDECHO" 0)
  (while (and
	   (not para)
	   (or ep
             (setq ss (SETVAR "NOMUTT" 1)
	           ss (princ "\nSelect object to trim (RIGH CLICK to EXIT)...")
	           ss (ssget "_+.:E:S" '((0 . "*LINE,POLYLINE,CIRCLE,ARC")))
    (SETVAR "NOMUTT" 0)
    (setq entUlt (entlast))
    (princ "\nSelect the object to split...")
    (setq ent (if ep (car ep) (ssname ss 0))
	  lstR (list
		 (cons 6 (if (assoc 6 (entget ent)) (cdr (assoc 6 (entget ent))) "BYLAYER"))
		 (cons 48 (if (assoc 48 (entget ent)) (cdr (assoc 48 (entget ent))) 1.0))
		 (cons 62 (if (assoc 62 (entget ent)) (cdr (assoc 62 (entget ent))) 256))
    (setq pt1 (getpoint "\nSelect the first break point: ") ;; Entering the first break point
	  pt2 (getpoint "\nSelect the second break point: ") ;; Entering the second break point
	  ep nil
    (vla-startUndomark (vla-get-activeDocument (vlax-get-acad-object)))
      ;; Checking the object type and performing the split
    (cond
      ((wcmatch (setq to (cdr (assoc 0 (entget ent)))) "*LINE")
	 ;; break polyline
       (setq pt1 (vlax-curve-getClosestPointTo (vlax-ename->vla-object ent) pt1)
	     pt2 (vlax-curve-getClosestPointTo (vlax-ename->vla-object ent) pt2)
       (command "_.BREAK" ent pt1 pt2)
       (command "_.LINE" pt1 pt2 "")
       (entmod (append (ENTGET (ENTLAST)) lstChg))
      ((= to "CIRCLE")
	 ;; break the circle
       (setvar "OSMODE" 0)
       (entmake (entget ent))
       (command "_.BREAK" (entlast) pt2 pt1)
       (setq lent (entget ent))
       (entmod (append (setq lent1 (entget (entlast))) lstChg))
       (setq para (= 0 (grreadea)))
      ((= to "ARC")
	 ;; break the arc
       (setvar "OSMODE" 0)
       (setq ;ent1 (entmake (entget ent))
	     pIni (vlax-curve-getPointatParam (setq vlae (vlax-ename->vla-object ent)) (vlax-curve-getStartParam vlae))
	     pt1 (polar (setq c (cdr (assoc 10 (setq lent (entget ent))))) (angle c pt1) (setq r (cdr (assoc 40 lent))))
	     pt2 (polar c (angle c pt2) r)
       (command "_.BREAK" ent pt1 pt1)
       (if (equal (car (nentselp pt2)) (setq ent1 (entlast))); SI P2 EST脕 SOBRE LA NUEVA ENTIDAD CREADA
	 (command "_.BREAK" ent1 pt2 pt2)
	 (command "_.BREAK" ent pt2 pt2)
       (entmod (append (entget (if (dameSeg (setq ent2 (entlast)) pt1 pt2) ent2 ent1)) lstChg))
      (T
       (prompt "An object of an unsupported type.")
    (vla-EndUndomark (vla-get-activeDocument (vlax-get-acad-object)))
    (setq eumk T)
    (setvar "OSMODE" OSMANT)
  (if ecoA (setvar "CMDECHO" ecoA))
  (if (not entUlt) (princ "\nObjects are not selected."))
  • Thanks 1
			  p1	  p2	  ent	  vlae	  ep
			  to	  c	  r	  eumk	  entdata
  (defun erroria ()
      (prin1)
	  *error* errores
    (if (and (or
	       (equal p1 pIni rg)
	       (equal p1 pFin rg)
	     (or
	       (equal p2 pIni rg)
	       (equal p2 pFin rg)
      T
    (while (not para)
      (cond
	((= (car lr) 2)
	 (cond
	   ((= (cadr lr) 9)
	((= (car lr) 3)
		 para (if ep T)
    para
  (erroria)
	eumk nil
	tl "DASHED2"
	     tl
	       (vlr-beep-reaction)
	       "CONTINUOUS"
	lstChg (list
		 '(62 . 84)     ; color
  (while (and
	   (not para)
	   (or ep
    (SETVAR "NOMUTT" 0)
	  lstR (list
	  ep nil
    (cond
	 ;; break polyline
      ((= to "CIRCLE")
	 ;; break the circle
       (setvar "OSMODE" 0)
      ((= to "ARC")
	 ;; break the arc
       (setvar "OSMODE" 0)
      (T
    (setq eumk T)
Another important detail: in the circles, the resulting arc that will be modified depends on whether the cut points are indicated in a clockwise or counterclockwise direction. If they are selected in the opposite direction from what is needed to obtain the desired result, it can be immediately switched by pressing TAB key (as indicated in the command line).
  • Thanks 1
@GLAVCVS Thank you very much, as always, you are very attentive to details.
It is very convenient that the functions work in a loop and a dashed line is created immediately.
"But in the end, I decided to spend a little time improving the code".
The code has been improved by 100 percent! 💯
Edited by Nikon
Why not use
(setvar 'osmode 512) ; as per NEAREST
	  ep nil
So point will be at select entity   and not need to get the closestpoint
Edited by devitg
Add new lines
12 minutes ago, devitg said:
Why not use
	  ep nil
The user can always activate the object snapping option using F3.
The reason I left this option is in case the user ever needs to reference the geometry of other nearby objects.
  • Agree 1
