Good day everyone!
I want to add several lisp files to the startup at once. I have a list of lisp files in notepad, in the Support folder.
The code returns an error: no function definition: VLA-GET-STARTUPSUITE
(defun c:add-list-lisps-to-startup ( / file line folder fullpath app ssuite )
  (vl-load-com)
  ;; The folder where the LISP files are located
  (setq folder "C:/Program Files/Autodesk/AutoCAD 2021/Support/")
  ;; Opening the list file
  (setq file (open "C:/Program Files/Autodesk/AutoCAD 2021/Support/list_startup.txt" "r"))
  (if file
      ;; Getting the object Application
      (setq app (vlax-get-acad-object))
      (setq ssuite (vla-get-StartupSuite app))
      (while (setq line (read-line file))
       (setq line (vl-string-trim " \t\r " line))
        (if (and line (> (strlen line) 0))
            (setq fullpath (strcat folder line))
            (if (findfile fullpath)
                (vla-Add ssuite fullpath)
                (princ (strcat "Added to auto-upload: " fullpath))
              (princ (strcat "File not found: " fullpath))
      ) ; end while
      (close file)
      (princ "All files from the list have been processed.")
    ) ; end progn
    (princ "Couldn't open the list file.")
  ) ; end if
) ; end defun
Edited by Nikon
That is because that is an AI generated function that does not exist. Rather than add them to the startup suite, just load them all using one lisp file:
(defun loadlisp	(path / lst pth)
  (if (and (setq pth (strcat (vl-string-right-trim "\\" path) "\\"))
	   (setq lst (vl-directory-files pth "*.lsp" 1))
    (foreach x (mapcar 'vl-filename-base lst) (vl-catch-all-apply 'load (list (strcat pth x))))
(loadlisp "C:\\Program Files\\Autodesk\\AutoCAD 2021\\Support\\")
Easy to inspect in the vlide:
Edited by ronjonp
1 hour ago, ronjonp said:
Rather than add them to the startup suite, just load them using one lisp file:
I need to add 50 lisp programs  to autoload...
I want to be able to upload lisp files not one, but in a list.
Edited by Nikon
Agree with Lee look into lisp built in functions, if you use Autoload function then its easy just need to add one lisp to the Start Up Suite. An example of the lsp file.
(autoload "COPY0" '("COPY0"))
(autoload "COPYCOMMAND" '("ZZZ"))
(autoload "COVER" '("COVER"))
(autoload "DIMFLIP" '("DIMFLIP"))
(autoload "DRAWXFALL" '("DRAWXFALL"))
(autoload "DRAWPIPE" '("DRAWPIPE"))
..... add more
  • Thanks 1
Yes
I think you should learn these simple things.
In any case, in situations like this, one way to avoid having to select the 50 lisp files one by one or, in the future, any group of files you need to load, is to create folders where you group and store the lisps needed for each task.
For example: you can create a folder called "Print", in which you store all your lisp files that you use to prepare a drawing for printing.
In this way, you would only need to create a command (for example "LoadFolder") that shows you a "dialogBox" to select the folder and load all its contents.
Edited by GLAVCVS
  • Thanks 1
A code as simple as this...
(defun c:LoadFolder (/ sh hwd carp slf pth lstAA a)
  (if (setq sh (vla-getinterfaceobject (vlax-get-acad-object) "shell.application")
	    hwd (vl-catch-all-apply 'vla-get-hwnd (list (vlax-get-acad-object)))
	    carp (vlax-invoke-method sh 'browseforfolder (if (vl-catch-all-error-p hwd) 0 hwd) "Folder lisp to load" 0 "")
    (if (setq slf (vlax-get-property carp 'self)
	      pth (vlax-get-property slf 'path)
	      pth (vl-string-right-trim "\\" (vl-string-translate "/" "\\" pth))
      (if (setq lstAA (vl-directory-files pth "*.lsp"))
	(foreach a lstAA
	  (load (strcat pth "\\" a))
        (alert "Nothing to load")
Edited by GLAVCVS
PS
The idea has more substance than the code itself
  • Agree 1
@Nikon
You should try what I posted. It will LOAD not AUTOLOAD all lisp files found within the folder "C:\\Program Files\\Autodesk\\AutoCAD 2021\\Support\\"
  • Thanks 1
I'll explain what it's for.
I had to transfer all the lisp files to a new computer, a little later, I reinstalled the Autocad version,
each time I added the files to the startup one at a time, since they are used in acad.pgp.
I load the rest of the lisp files using strings like:
(_autoload "ObjectBreakV1-0")(c:brk)
(_autoload "ObjectBreakV1-0")(c:brko)
(_autoload "unformat_LM")(c:unformat_LM)
The list of files (_autoload... located in the .dwg template
Therefore, there was a question about uploading files as a list.
Do I understand correctly?
The LoadFolder code opens a folder selection dialog, searches for all lisp files in the selected folder,
and automatically downloads all lisp files (*.lsp) from this folder.
That is, should I sort the lisp files for autoloading into a separate folder?
With more than 300 files, sorting will take a long time...
Therefore, I decided that it would be easier to have a list of lisp files in notepad and upload this list.
Is it possible to implement this in code?
Why not use a pop menu a toolbar or a ribbon then all your lisps are available. This has 130 lisp's behind it. You can check if loaded already else load it.
  • Thanks 1
@BIGAL's option is a very good one.
Regarding your question about writing the LISPs to load to a file, the code can be easily adapted to that.
But I think it would take the same amount of time as writing it to a file:
- Option 1: Write the names of the LISPs to load to a file: find the file name in the folder, write the file name, and then correct 5% of the names (statistically, I think you'd write 5% of the names with some kind of error. That will waste your time later trying to figure out what's wrong and correcting the file).
ESTIMATED AVERAGE TIME (my own) FOR ALL THIS: 15 seconds per file
- Option 2: Select each file to copy in Windows Explorer, Control+C, find the destination folder, Control+V, and then Windows should take about 5 seconds to complete this task. ESTIMATED TIME (my estimate) FOR ALL OF THIS: LESS THAN 10 SECONDS PER FILE.
Based on this, for me, the choice is clear.
But if you're sure you prefer the file option, then just open (or create, if you don't have one) the "acad. lsp" file and write a line like this for each file you want to load:
(load "filename.lsp")
PS
In the latter case, you will need to include the location of your lisp files in the AutoCAD search paths list.
Edited by GLAVCVS
  • Thanks 1
Is it possible to use lisp to get a list of lisp files? (in the form of a text file, put the file on the desktop),which are in the startup.
