Hi everyone
When I open a dwg file and use the attached lisp to change the Qleader settings, no changes are made to the settings.
Please fix the problem for me.
qlset.lsp.lsp test.dwg
That LISP the is not original AFAIK.
It is a couple of functions, you need to call for it with a LISP to make the settings, etc.
Several places to get the correct QlSet.lsp and example LISPs to use it.
Qleader lisp routine - AutoLISP, Visual LISP & DCL - AutoCAD Forums
Qleader System Variables - AutoLISP, Visual LISP & DCL - AutoCAD Forums
qleader lisp - AutoLISP, Visual LISP & DCL - AutoCAD Forums
assigning q-leader settings using lisp
