X11start Posted Saturday at 06:28 AM Posted Saturday at 06:28 AM I made a stupid mistake and now I would like to find a way to avoid it: I copied a portion of a drawing (using CTRL+C) and pasted it into another (CTRL+V). The problem is that the copied part contained blocks that were already present with the same name in the new drawing. However, the blocks in the new drawing were slightly different. Is it possible to create a lisp or something that warns: 'Attention: the drawing already contains blocks named XXXX'? Quote
GLAVCVS Posted Saturday at 09:06 AM Posted Saturday at 09:06 AM Perhaps someone knows a better way. In my opinion, this could be done with reactors. That is, in your AutoCAD session, there should be two latent reactors: one that activates after "copyclip" is executed and looks for the most recent DWG in the "temp" folder and saves its name in a global variable; and another that activates just before "pasteclip" is executed (:vlr-commandWillStart) and tracks the blocks of the DWG where the "copyclip" was created and the blocks of the current drawing. There may already be a Lisp published in this forum that does this job, and some veteran can help you locate it. Quote
Nikon Posted Saturday at 10:11 AM Posted Saturday at 10:11 AM (edited) 6 hours ago, X11start said: Is it possible to create a lisp or something that warns: 'Attention: the drawing already contains blocks named XXXX'? It would be nice to add a request along with the warning.: (setq choice (getkword "[Continue/caNcel/Rename/Add-index-1] <Rename>: ")) Edited Saturday at 01:06 PM by Nikon Quote
X11start Posted Saturday at 12:30 PM Author Posted Saturday at 12:30 PM Thank you very much, I also thought that the solution was to use Reactors... but creating a Lisp of this kind is way beyond my abilities! I hope that someone among the 'gurus' of this forum can help me. Thank you. Quote
Steven P Posted Saturday at 12:49 PM Posted Saturday at 12:49 PM Could do it with pure LISP rather than reactors, a new name though ("CopyWithBlocks" and "PasteWithBlocks" or something like that. CwB, PwB) Weekend so CAD is off but something like this Copy: Select all the entities required in a selection set Select the basepoint (or use a nominal one if necessary) Loop through the selection set to find all the block names Save this list as a variable - or if you want to be really clever - add this list to the copied information (never tried that but I think it is possible), perhaps as xdata in a point or something that can later be found and deleted Copy to clipboard: (vl-cmdf "_.copyclip" basepoint MySS "") (vl-cmdf "_.copybase" basepoint MySS "") Paste: Find the list of blocks from the xdata, and create a list of blocks in the target drawing Compare the 2 lists and give any warnings necessary If OK, paste. If not OK don't paste. Quote
rlx Posted Saturday at 04:31 PM Posted Saturday at 04:31 PM (edited) maybe something like this (untested) ;;; copy & paste for dummies - rlx 2025-10-18 (defun c:capfd ( / this-dwg ss other-dwg blocknames-in-selectionset blocknames-in-other-dwg duplicate-blocknames) (setq this-dwg (vla-get-ActiveDocument (vlax-get-acad-object))) (if (and (setq ss (ssget)) (setq other-dwg (getfiled "Copy SS to:" "" "dwg" 0))) (progn (setq blocknames-in-selectionset (Get_SS_BlockNames ss)) (setq blocknames-in-other-dwg (Get_DBX_Blocknames other-dwg)) (setq duplicate-blocknames (compare_block_names blocknames-in-selectionset blocknames-in-other-dwg)) (if (vl-consp duplicate-blocknames) (progn (dplm duplicate-blocknames "Duplicated block names : ") (if (yes_no "Copy anyway?") (ctd ss other-dwg) (princ"\nBite me...") ) ) (ctd ss other-dwg) ) ) ) (princ) ) (defun compare_block_names (a b / c) (and (vl-consp a) (vl-consp b) (foreach item a (if (member item b) (setq c (cons item c))))) c) (defun Get_SS_BlockNames ( ss / n l) (foreach o (ss->ol ss) (if (and (block-p o)(not (member (setq n (block-n o)) l))) (setq l (cons n l)))) l) (defun SS->OL (ss / i l)(setq i 0)(repeat (sslength ss)(setq l (cons (vlax-ename->vla-object (ssname ss i)) l) i (1+ i))) l) ; (block-p (vlax-ename->vla-object (car (entsel)))) (defun block-p (o) (and (= 'vla-object (type O))(eq (vla-get-objectname O) "AcDbBlockReference"))) (defun block-n (o) (if (and (= 'vla-object (type O))(eq (vla-get-objectname O) "AcDbBlockReference")) (if (vlax-property-available-p o 'EffectiveName)(vla-Get-EffectiveName o)(vla-Get-Name o)) nil)) ; (yes_no "Do you like snow") (defun yes_no ( $m / f p i r ) (and (= (type $m) 'STR) (setq f (vl-filename-mktemp ".dcl")) (setq p (open f "w")) (write-line (strcat "yesno:dialog{label=\"" $m "?\";ok_cancel;}") p) (progn (close p)(gc) t) (setq i (load_dialog f)) (new_dialog "yesno" i) (progn (action_tile "accept" "(done_dialog 1)")(action_tile "cancel" "(done_dialog 0)") (setq r (start_dialog))(unload_dialog i)(vl-file-delete f) t)(if (= r 1) t nil))) ;;; display list (plus message) (defun dplm (l m / f p d w) (and (vl-consp l) (setq l (mapcar 'vl-princ-to-string l)) (setq w (+ 5 (apply 'max (mapcar 'strlen l)))) (setq p (open (setq f (vl-filename-mktemp ".dcl")) "w")) (princ (strcat "cfl:dialog{label=\"" m "\";:list_box {key=\"lb\";" "width="(itoa w)";}ok_only;}") p)(not (setq p (close p)))(< 0 (setq d (load_dialog f)))(new_dialog "cfl" d)(progn (start_list "lb") (mapcar 'add_list l)(end_list)(action_tile "accept" "(done_dialog)")(start_dialog)(unload_dialog d)(vl-file-delete f)))) ;;; copy to drawing (defun ctd ( ss dwg / ss->ol dbx_ver acApp acDoc dbx object-list object-safe-array) (defun SS->OL (ss / i l) (setq i 0)(repeat (sslength ss)(setq l (cons (vlax-ename->vla-object (ssname ss i)) l) i (1+ i))) l) (defun dbx_ver ( / v) (strcat "objectdbx.axdbdocument" (if (< (setq v (atoi (getvar 'acadver))) 16) "" (strcat "." (itoa v))))) (setq acApp (vlax-get-acad-object) acDoc (vla-get-ActiveDocument acApp)) (setq dbx (vl-catch-all-apply 'vla-getinterfaceobject (list acApp (dbx_ver)))) (vla-open dbx dwg) ; put all block objects in a list (setq object-list (ss->ol ss)) ; put list with objects in a safe array (setq object-safe-array (vlax-make-safearray vlax-vbobject (cons 0 (1- (length object-list))))) (vl-catch-all-apply 'vlax-safearray-fill (list object-safe-array object-list)) ; copy objects to dbx-drawing (vla-CopyObjects acDoc object-safe-array (vla-get-ModelSpace dbx)) (vl-catch-all-apply 'vla-saveas (list dbx dwg)) (vl-catch-all-apply 'vlax-release-object (list dbx)) (setq object-list nil object-safe-array nil) (princ) ) ; test : (setq lst (GetDocBlockNames (vla-get-ActiveDocument (vlax-get-acad-object)))) ; returns sorted list (uppercase) like : ("BLOCK_A" "BLOCK_B" ...) (defun GetDocBlockNames (d / o n l) (vlax-for o (vla-get-blocks d)(if (and (= :vlax-false (vla-get-isxref o))(= :vlax-false (vla-get-islayout o)) (snvalid (setq n (vla-get-name o)) 0))(setq l (cons (strcase n) l))))(if (vl-consp l)(acad_strlsort l))) (defun Get_DBX_Blocknames ( doc-name / lst v objectdbx-document) (cond ((not (eq (type doc-name) 'STR)) (princ (strcat "\nInvalid filename : " (vl-princ-to-string doc-name)))) ((not (findfile doc-name)) (princ (strcat "\nFile not found : " (vl-princ-to-string doc-name)))) (t (vlax-for doc (vla-get-Documents (vlax-get-acad-object)) (and (eq (strcase (vla-get-fullname doc)) (strcase doc-name))(setq objectdbx-document doc))) (cond ((eq (type objectdbx-document) 'VLA-OBJECT)) ((not (setq objectdbx-document (vlax-create-object (strcat "objectdbx.axdbdocument" (if (< (setq v (atoi (getvar 'acadver))) 16) "" (strcat "." (itoa v))))))) (princ "\nUnable to start object dbx")) ((vl-catch-all-error-p (vl-catch-all-apply 'vla-open (list objectdbx-document doc-name))) (princ (strcat "\nOdbx error - unable to acces : " doc-name))) (t (setq lst (GetDocBlockNames objectdbx-document))) ) ) ) (vl-catch-all-apply 'vla-close (list objectdbx-document :vlax-False)) (if (and (= 'vla-object (type objectdbx-document))(not (vlax-object-released-p objectdbx-document))) (vlax-release-object objectdbx-document)) (if (vl-consp lst) (mapcar 'strcase lst)) ) and if you want the rename version : ;;; copy for lazy dummies - rlx 2025-10-18 (defun c:cfld ( / this-dwg ss other-dwg blocknames-in-selectionset blocknames-in-other-dwg duplicate-blocknames) (setq this-dwg (vla-get-ActiveDocument (vlax-get-acad-object))) (if (and (setq ss (ssget)) (setq other-dwg (getfiled "Copy SS to:" "" "dwg" 0))) (progn (if (vl-consp (setq blocknames-in-selectionset (Get_SS_BlockNames ss))) (setq blocknames-in-selectionset (mapcar 'strcase blocknames-in-selectionset))) (if (vl-consp (setq blocknames-in-other-dwg (Get_DBX_Blocknames other-dwg))) (setq blocknames-in-other-dwg (mapcar 'strcase blocknames-in-other-dwg))) (setq duplicate-blocknames (compare_block_names blocknames-in-selectionset blocknames-in-other-dwg)) (if (vl-consp duplicate-blocknames) (progn (dplm duplicate-blocknames "Duplicated block names : ") ;;; (if (yes_no "Copy anyway?") (ctd ss other-dwg) (princ"\nBite me...") ) (if (yes_no "Rename duplicates?") (progn (foreach b duplicate-blocknames (rename_block_definition b)) (ctd ss other-dwg) ) (princ"\nBite me...") ) ) (ctd ss other-dwg) ) ) ) (princ) ) ; check if $member exists in (vla-) %collection (defun Collection-Member ( $member %collection / result) (if (vl-catch-all-error-p (setq result (vl-catch-all-apply 'vla-item (list %collection $member)))) nil result)) (defun create_unique_blockname ( $bn / i bn) (setq i 0)(while (tblsearch "block" (setq bn (strcat $bn "_" (itoa (setq i (1+ i))))))) bn) (defun rename_block_definition ( $bn / bn ) (if (and (not (void $bn)) (tblsearch "block" $bn)) (vla-put-name (Collection-Member $bn (vla-get-blocks (vla-get-ActiveDocument (vlax-get-acad-object)))) (setq bn (create_unique_blockname $bn)))) bn) (defun compare_block_names (a b / c) (and (vl-consp a) (vl-consp b) (foreach item a (if (member item b) (setq c (cons item c))))) c) (defun Get_SS_BlockNames ( ss / n l) (foreach o (ss->ol ss) (if (and (block-p o)(not (member (setq n (block-n o)) l))) (setq l (cons n l)))) l) (defun SS->OL (ss / i l)(setq i 0)(repeat (sslength ss)(setq l (cons (vlax-ename->vla-object (ssname ss i)) l) i (1+ i))) l) ; (block-p (vlax-ename->vla-object (car (entsel)))) (defun block-p (o) (and (= 'vla-object (type O))(eq (vla-get-objectname O) "AcDbBlockReference"))) (defun block-n (o) (if (and (= 'vla-object (type O))(eq (vla-get-objectname O) "AcDbBlockReference")) (if (vlax-property-available-p o 'EffectiveName)(vla-Get-EffectiveName o)(vla-Get-Name o)) nil)) ; (yes_no "Do you like snow") (defun yes_no ( $m / f p i r ) (and (= (type $m) 'STR) (setq f (vl-filename-mktemp ".dcl")) (setq p (open f "w")) (write-line (strcat "yesno:dialog{label=\"" $m "?\";ok_cancel;}") p) (progn (close p)(gc) t) (setq i (load_dialog f)) (new_dialog "yesno" i) (progn (action_tile "accept" "(done_dialog 1)")(action_tile "cancel" "(done_dialog 0)") (setq r (start_dialog))(unload_dialog i)(vl-file-delete f) t)(if (= r 1) t nil))) ;;; display list (plus message) (defun dplm (l m / f p d w) (and (vl-consp l) (setq l (mapcar 'vl-princ-to-string l)) (setq w (+ 5 (apply 'max (mapcar 'strlen l)))) (setq p (open (setq f (vl-filename-mktemp ".dcl")) "w")) (princ (strcat "cfl:dialog{label=\"" m "\";:list_box {key=\"lb\";" "width="(itoa w)";}ok_only;}") p)(not (setq p (close p)))(< 0 (setq d (load_dialog f)))(new_dialog "cfl" d)(progn (start_list "lb") (mapcar 'add_list l)(end_list)(action_tile "accept" "(done_dialog)")(start_dialog)(unload_dialog d)(vl-file-delete f)))) ;;; copy to drawing (defun ctd ( ss dwg / ss->ol dbx_ver acApp acDoc dbx object-list object-safe-array) (defun SS->OL (ss / i l) (setq i 0)(repeat (sslength ss)(setq l (cons (vlax-ename->vla-object (ssname ss i)) l) i (1+ i))) l) (defun dbx_ver ( / v) (strcat "objectdbx.axdbdocument" (if (< (setq v (atoi (getvar 'acadver))) 16) "" (strcat "." (itoa v))))) (setq acApp (vlax-get-acad-object) acDoc (vla-get-ActiveDocument acApp)) (setq dbx (vl-catch-all-apply 'vla-getinterfaceobject (list acApp (dbx_ver)))) (vla-open dbx dwg) ; put all block objects in a list (setq object-list (ss->ol ss)) ; put list with objects in a safe array (setq object-safe-array (vlax-make-safearray vlax-vbobject (cons 0 (1- (length object-list))))) (vl-catch-all-apply 'vlax-safearray-fill (list object-safe-array object-list)) ; copy objects to dbx-drawing (vla-CopyObjects acDoc object-safe-array (vla-get-ModelSpace dbx)) (vl-catch-all-apply 'vla-saveas (list dbx dwg)) (vl-catch-all-apply 'vlax-release-object (list dbx)) (setq object-list nil object-safe-array nil) (princ) ) ; test : (setq lst (GetDocBlockNames (vla-get-ActiveDocument (vlax-get-acad-object)))) ; returns sorted list (uppercase) like : ("BLOCK_A" "BLOCK_B" ...) (defun GetDocBlockNames (d / o n l) (vlax-for o (vla-get-blocks d)(if (and (= :vlax-false (vla-get-isxref o))(= :vlax-false (vla-get-islayout o)) (snvalid (setq n (vla-get-name o)) 0))(setq l (cons (strcase n) l))))(if (vl-consp l)(acad_strlsort l))) (defun Get_DBX_Blocknames ( doc-name / lst v objectdbx-document) (cond ((not (eq (type doc-name) 'STR)) (princ (strcat "\nInvalid filename : " (vl-princ-to-string doc-name)))) ((not (findfile doc-name)) (princ (strcat "\nFile not found : " (vl-princ-to-string doc-name)))) (t (vlax-for doc (vla-get-Documents (vlax-get-acad-object)) (and (eq (strcase (vla-get-fullname doc)) (strcase doc-name))(setq objectdbx-document doc))) (cond ((eq (type objectdbx-document) 'VLA-OBJECT)) ((not (setq objectdbx-document (vlax-create-object (strcat "objectdbx.axdbdocument" (if (< (setq v (atoi (getvar 'acadver))) 16) "" (strcat "." (itoa v))))))) (princ "\nUnable to start object dbx")) ((vl-catch-all-error-p (vl-catch-all-apply 'vla-open (list objectdbx-document doc-name))) (princ (strcat "\nOdbx error - unable to acces : " doc-name))) (t (setq lst (GetDocBlockNames objectdbx-document))) ) ) ) (vl-catch-all-apply 'vla-close (list objectdbx-document :vlax-False)) (if (and (= 'vla-object (type objectdbx-document))(not (vlax-object-released-p objectdbx-document))) (vlax-release-object objectdbx-document)) (if (vl-consp lst) (mapcar 'strcase lst)) ) (c:cfld) Edited Saturday at 09:55 PM by rlx 2 Quote
X11start Posted Sunday at 08:29 AM Author Posted Sunday at 08:29 AM (edited) I tested both files: the 2nd one (the one that allows renaming), I don't understand how it works: I can't rename the block already present on the first drawing. ... but the first lisp is more than sufficient: from now on, whenever I want to do a "Copy and paste at the original coordinates", I will definitely use 'capdf.lsp'! An 'Alert' that warns me there are blocks with the same name already present in the 2nd drawing... is more than enough to avoid making dangerous mistakes! I thank you immensely, RLX, for all the work you have done! A note (I also say this for other users): remember to add (vl-load-com), if it is not already included in the auto start when launching AutoCAD. Edited Sunday at 08:44 AM by X11start Quote
rlx Posted Sunday at 12:54 PM Posted Sunday at 12:54 PM (edited) You're welcome @X11start If you want options for rename you can try this copy for dragons version ;;; copy for dragons- rlx 2025-10-18 (defun c:cfd ( / this-dwg ss other-dwg blocknames-in-selectionset blocknames-in-other-dwg duplicate-blocknames dbx-doc) (setq this-dwg (vla-get-ActiveDocument (vlax-get-acad-object))) (if (and (setq ss (ssget)) (setq other-dwg (getfiled "Copy SS to:" "" "dwg" 0))) (progn (if (vl-consp (setq blocknames-in-selectionset (Get_SS_BlockNames ss))) (setq blocknames-in-selectionset (mapcar 'strcase blocknames-in-selectionset))) (if (vl-consp (setq blocknames-in-other-dwg (Get_DBX_Blocknames other-dwg))) (setq blocknames-in-other-dwg (mapcar 'strcase blocknames-in-other-dwg))) (setq duplicate-blocknames (compare_block_names blocknames-in-selectionset blocknames-in-other-dwg)) (if (vl-consp duplicate-blocknames) (progn (dplm duplicate-blocknames "Duplicated block names : ") ;;; (if (yes_no "Copy anyway?") (ctd ss other-dwg) (princ"\nBite me...") ) (setq inp (cfl (list "1 - Copy anyway" "2 - Rename blocks in this dwg" "3 - Rename blocks in other dwg" "4 - Never mind"))) (cond ((void inp) (princ "\nNever mind")) ((wcmatch inp "1*") (ctd ss other-dwg)) ((wcmatch inp "2*") (foreach b duplicate-blocknames (rename_block_definition b)) (ctd ss other-dwg)) ((wcmatch inp "3*") (dbx_rename_block_definitions duplicate-blocknames other-dwg) (ctd ss other-dwg)) (t (princ"\nBite me...")) ) ) (ctd ss other-dwg) ) ) ) (princ) ) ; check if $member exists in (vla-) %collection (defun Collection-Member ( $member %collection / result) (if (vl-catch-all-error-p (setq result (vl-catch-all-apply 'vla-item (list %collection $member)))) nil result)) (defun create_unique_blockname ( $bn / i bn) (setq i 0)(while (tblsearch "block" (setq bn (strcat $bn "_" (itoa (setq i (1+ i))))))) bn) (defun rename_block_definition ( $bn / bn ) (if (and (not (void $bn)) (tblsearch "block" $bn)) (vla-put-name (Collection-Member $bn (vla-get-blocks (vla-get-ActiveDocument (vlax-get-acad-object)))) (setq bn (create_unique_blockname $bn)))) bn) (defun compare_block_names (a b / c) (and (vl-consp a) (vl-consp b) (foreach item a (if (member item b) (setq c (cons item c))))) c) (defun Get_SS_BlockNames ( ss / n l) (foreach o (ss->ol ss) (if (and (block-p o)(not (member (setq n (block-n o)) l))) (setq l (cons n l)))) l) (defun SS->OL (ss / i l)(setq i 0)(repeat (sslength ss)(setq l (cons (vlax-ename->vla-object (ssname ss i)) l) i (1+ i))) l) (defun void (x) (or (eq x nil)(and (listp x)(not (vl-consp x)))(and (eq 'STR (type x))(eq "" (vl-string-trim " \t\r\n" x))))) ; (block-p (vlax-ename->vla-object (car (entsel)))) (defun block-p (o) (and (= 'vla-object (type O))(eq (vla-get-objectname O) "AcDbBlockReference"))) (defun block-n (o) (if (and (= 'vla-object (type O))(eq (vla-get-objectname O) "AcDbBlockReference")) (if (vlax-property-available-p o 'EffectiveName)(vla-Get-EffectiveName o)(vla-Get-Name o)) nil)) ; (yes_no "Do you like snow") (defun yes_no ( $m / f p i r ) (and (= (type $m) 'STR) (setq f (vl-filename-mktemp ".dcl")) (setq p (open f "w")) (write-line (strcat "yesno:dialog{label=\"" $m "?\";ok_cancel;}") p) (progn (close p)(gc) t) (setq i (load_dialog f)) (new_dialog "yesno" i) (progn (action_tile "accept" "(done_dialog 1)")(action_tile "cancel" "(done_dialog 0)") (setq r (start_dialog))(unload_dialog i)(vl-file-delete f) t)(if (= r 1) t nil))) ;;; choose from list (cfl '("1""2""3")) (defun cfl (l / f p d r) (and (setq p (open (setq f (vl-filename-mktemp ".dcl")) "w")) (princ "cfl:dialog{label=\"Choose\";:list_box{key=\"lb\";width=40;}ok_cancel;}" p) (not (setq p (close p)))(< 0 (setq d (load_dialog f)))(new_dialog "cfl" d) (progn (start_list "lb")(mapcar 'add_list l)(end_list)(action_tile "lb" "(setq r (nth (atoi $value) l))(done_dialog 1)") (action_tile "accept" "(setq r (get_tile \"lb\"))(done_dialog 1)")(action_tile "cancel" "(setq r nil)(done_dialog 0)") (start_dialog)(unload_dialog d)(vl-file-delete f))) (cond ((= r "") nil)(r r)(t nil))) ;;; display list (plus message) (defun dplm (l m / f p d w) (and (vl-consp l) (setq l (mapcar 'vl-princ-to-string l)) (setq w (+ 5 (apply 'max (mapcar 'strlen l)))) (setq p (open (setq f (vl-filename-mktemp ".dcl")) "w")) (princ (strcat "cfl:dialog{label=\"" m "\";:list_box {key=\"lb\";" "width="(itoa w)";}ok_only;}") p)(not (setq p (close p)))(< 0 (setq d (load_dialog f)))(new_dialog "cfl" d)(progn (start_list "lb") (mapcar 'add_list l)(end_list)(action_tile "accept" "(done_dialog)")(start_dialog)(unload_dialog d)(vl-file-delete f)))) ;;; copy to drawing (defun ctd ( ss dwg / ss->ol dbx_ver acApp acDoc dbx object-list object-safe-array) (defun SS->OL (ss / i l) (setq i 0)(repeat (sslength ss)(setq l (cons (vlax-ename->vla-object (ssname ss i)) l) i (1+ i))) l) (defun dbx_ver ( / v) (strcat "objectdbx.axdbdocument" (if (< (setq v (atoi (getvar 'acadver))) 16) "" (strcat "." (itoa v))))) (setq acApp (vlax-get-acad-object) acDoc (vla-get-ActiveDocument acApp)) (setq dbx (vl-catch-all-apply 'vla-getinterfaceobject (list acApp (dbx_ver)))) (vla-open dbx dwg) ; put all objects in a list (setq object-list (ss->ol ss)) ; put list with objects in a safe array (setq object-safe-array (vlax-make-safearray vlax-vbobject (cons 0 (1- (length object-list))))) (vl-catch-all-apply 'vlax-safearray-fill (list object-safe-array object-list)) ; copy objects to dbx-drawing (vla-CopyObjects acDoc object-safe-array (vla-get-ModelSpace dbx)) (vl-catch-all-apply 'vla-saveas (list dbx dwg)) (vl-catch-all-apply 'vlax-release-object (list dbx)) (setq object-list nil object-safe-array nil) (princ) ) ;;; (dbx_rename_block_definitions ("block-a" "block-b" "block-c") "c:\\temp\\my-old-blocks-drawing.dwg") (defun dbx_rename_block_definitions ( lst dwg / dbx_ver acApp acDoc dbx dbx-blocks) (defun dbx_ver ( / v) (strcat "objectdbx.axdbdocument" (if (< (setq v (atoi (getvar 'acadver))) 16) "" (strcat "." (itoa v))))) (setq acApp (vlax-get-acad-object) acDoc (vla-get-ActiveDocument acApp)) (setq dbx (vl-catch-all-apply 'vla-getinterfaceobject (list acApp (dbx_ver)))) (vla-open dbx dwg) (setq dbx-blocks (vla-get-blocks dbx)) (foreach blk lst (if (Collection-Member blk dbx-blocks) (vla-put-name (Collection-Member blk dbx-blocks) (create_unique_blockname blk)))) (vl-catch-all-apply 'vla-saveas (list dbx dwg)) (vl-catch-all-apply 'vlax-release-object (list dbx)) (princ) ) ; test : (setq lst (GetDocBlockNames (vla-get-ActiveDocument (vlax-get-acad-object)))) ; returns sorted list (uppercase) like : ("BLOCK_A" "BLOCK_B" ...) (defun GetDocBlockNames (d / o n l) (vlax-for o (vla-get-blocks d)(if (and (= :vlax-false (vla-get-isxref o))(= :vlax-false (vla-get-islayout o)) (snvalid (setq n (vla-get-name o)) 0))(setq l (cons (strcase n) l))))(if (vl-consp l)(acad_strlsort l))) (defun Get_DBX_Blocknames ( doc-name / lst v objectdbx-document) (cond ((not (eq (type doc-name) 'STR)) (princ (strcat "\nInvalid filename : " (vl-princ-to-string doc-name)))) ((not (findfile doc-name)) (princ (strcat "\nFile not found : " (vl-princ-to-string doc-name)))) (t (vlax-for doc (vla-get-Documents (vlax-get-acad-object)) (and (eq (strcase (vla-get-fullname doc)) (strcase doc-name))(setq objectdbx-document doc))) (cond ((eq (type objectdbx-document) 'VLA-OBJECT)) ((not (setq objectdbx-document (vlax-create-object (strcat "objectdbx.axdbdocument" (if (< (setq v (atoi (getvar 'acadver))) 16) "" (strcat "." (itoa v))))))) (princ "\nUnable to start object dbx")) ((vl-catch-all-error-p (vl-catch-all-apply 'vla-open (list objectdbx-document doc-name))) (princ (strcat "\nOdbx error - unable to acces : " doc-name))) (t (setq lst (GetDocBlockNames objectdbx-document))) ) ) ) (vl-catch-all-apply 'vla-close (list objectdbx-document :vlax-False)) (if (and (= 'vla-object (type objectdbx-document))(not (vlax-object-released-p objectdbx-document))) (vlax-release-object objectdbx-document)) (if (vl-consp lst) (mapcar 'strcase lst)) ) (c:cfd) Edited Sunday at 05:52 PM by rlx Quote
X11start Posted Monday at 07:13 AM Author Posted Monday at 07:13 AM (edited) DWG1.dwg DWG2.dwg Edited Monday at 07:15 AM by X11start Quote
rlx Posted Monday at 07:59 AM Posted Monday at 07:59 AM these days I also can't copy / paste / download on my worklaptop but will have a look tonight. Maybe make sure the drawing you copy to is closed. I only tested it once on my home laptop and had nos problemos you knowos... and maybe look for locked layers? Just hope I can still post... Quote
X11start Posted Monday at 09:38 AM Author Posted Monday at 09:38 AM ... Don't worry: take it slow. Even my home PC went crazy yesterday: the screen was filled with colored squares and everything froze! These PCs are unpredictable... like a woman! Maybe that's their charm! Quote
rlx Posted Monday at 02:49 PM Posted Monday at 02:49 PM well , downloaded your files on my homedragon and no errors on my side , maybe others can give it a go and see if they get an error? 1 Quote
X11start Posted 19 hours ago Author Posted 19 hours ago ... I didn't tell you that I use GStarCAD: this would be one of the very rare cases where an AutoCAD lisp is not compatible with GStarCAD! I need to try it on a co-worker PC: they use AutoCAD LT (which should now make the lisps work... let's hope also the VL-XXX ones!). Anyway, thank you for your availability. Quote
X11start Posted 6 hours ago Author Posted 6 hours ago I checked: it works on Autocad... on GstarCAD it doesn't work. It doesn't matter, I use your previous file that reported the error but didn't allow renaming (CAPFD) thank you so much RLX for your effort! 1 Quote
GLAVCVS Posted 5 hours ago Posted 5 hours ago On 10/20/2025 at 9:13 AM, X11start said: DWG1.dwg 139,09 kB · 2 descargas DWG2.dwg 139,34 kB · 1 descarga Hello The problem may be in ObjectDBX. Try replacing "objectdbx.axdbdocument" with "GStarX.axdbdocument" Quote
